Sharpen a Nail Clipper
Intro: Sharpen a Nail Clipper
Many years ago when this nail clipper was new I needed to cut a couple of fine copper wires. I had nothing else at the time and I used my nail clipper. The wires made nicks in the cutting edges of the clipper. Eventually I learned a way to sharpen the clipper's cutting edges evenly and did so. (Ignore the surface rust that has appeared in the years since.)
STEP 1: Remove the Actuating Lever
The jaws will need to be held in position for sharpening. You need some precision difficult to obtain by using the actuating lever alone. Remove it by squeezing the jaws together with your thumbs or thumb and first finger, or with a pair of pliers as shown here. The lever falls out of the pin. Remove the pin.
STEP 2: Bring the Jaws Together
Insert a screw into the hole for the pin and put a nut onto the threads. Tighten the screw and nut to pull the cutting edges on the jaws lightly together or nearly so. They could be even closer together than shown here.
STEP 3: Sharpen
The nail clipper has a flat face at the cutting edges on the front of the jaws. Grinding this flat surface will sharpen the cutting edges equally.
This clipper has a mildly convex surface, so it is easy to grind on a flat sharpening stone. Some clippers are rather sharply concave on the front of the jaws. Light passes with a very fine grinding stone in a Dremel tool will work nicely. Continue grinding lightly until all nicks in the cutting edges disappear. You may need to tighten the screw and nut a little as you go to keep the cutting edges close to one another while you grind. When you are finished, you will have two factory new cutting surfaces and your clippers will work great once again. When finished grinding remove the screw and nut. Insert the pin. Squeeze the jaws together a bit and attach the actuating lever. Wash the clipper to remove any grit from grinding the cutting edges.
85 Comments
PoisonDWARFnz 6 years ago
Thank you for the tutorial, worked very well.
Phil B 6 years ago
Thanks. I am glad it was helpful.
Old Toad 8 years ago
Thanks for the tutorial! I stumbled on this while searching for an affordable decent nail clippers. In the 80's I remember buying USA made nail clippers for under $1. Eventually I lost them all and tried buying new ones made in China, but was not happy with the way they cut (hacked) my nails leaving them rough. I gave up buying new ones and bought a (new) USA made one at a train show for $4. It came in a leather key chain case and it and the case were engraved or stamped with the Illinois Central logo. I keep them hidden from the wife and kids, so they have not been lost. I no longer keep any in the cars or my desk at work as I haven't found decent ones for a reasonable price. You can pay as much as $45 for a pair, made in USA, I saw online today. I think your tutorial will help me to hone cheap, new clippers that are stamped out of poor quality steel with worn out dies and factory ground with course grind stones. I have seen, besides the $2 bulk ones at the cas register that don't cut well, $10 ones in the beauty section, but who wants to pay that much for clippers for the cars or that may be lost, when the online reviews of those brands are not so favorable either? Life used to be more simple when quality products were produced domestically at a reasonable price. Anyway.... Thanks!
Phil B 6 years ago
somehow I missed your comment. Thanks.
PeggyS31 8 years ago
mikeasaurus 15 years ago
I like renewing just about anything (even tools), however you have to wonder if the time spent is worth it. I mean I don't re-bend my used staples. I guess my question is: why bother?
I find new clippers (China) cut worse than my old USA made ones. There is a USA made one available online for $45...perhaps I will try this method to sharpen cheap NEW clippers! The days of functional USA made clippers for a buck (or any reasonable price) are over. I stopped buying the new ones as the cut my nails so roughly! I think it is worth it.
mikeasaurus 13 years ago
Phil B 13 years ago
AlphaRomeo 11 years ago
BTW - I will be sharpening my nail clipper this week end.
Phil B 11 years ago
Thank you for looking at this. I do not know why it is suddenly gathering so much attention. It got linked somewhere after plodding along for a couple of years and now is drawing all manner of attention. Enjoy your newly sharpened clippers.
Jehu_McSpooran 11 years ago
Phil B 11 years ago
As for my clippers, those need sharpening - the cutting edges are gagged and I have to first grind the cutting edges so they meet evenly with each other.
carmstrong2 11 years ago
Phil B 15 years ago
girlcousin 11 years ago
Phil B 11 years ago
Phil B 11 years ago
