Introduction: Sheet Bend
Hi and welcome to another Instructable by me Capsos.
I do hope you enjoy these and please make sure you check out my other Instructables on here, Also with that if you are into Bushcraft or would like to see a little more on what I teach then please check my Instagram page Capsos_Bushcraft Have a brilliant day and please like this and leave a comment below. Thankyou
The Sheet Bend is recommended for joining two ropes of unequal size. The thicker rope should be used for the simple bight. It works equally well if the ropes are the same size.
Step 1:
Take the thicker of the two ropes that you wish to join together and double it back on itself. (Creating a Bight)
Step 2:
Now take the thinner of the two ropes you wish to join and feed it upwards through the loop (Bight) of the larger.
Step 3:
Now feed it behind both Feed and short end of the thicker rope.
Step 4:
Now feed it under itself from where it entered.
Step 5:
Now all that is left to do is pull tight.
Progress to next stage if you wish to add extra strength to this knot.
Step 6:
To make it stronger, loop the thinner rope around twice before feeding it back under itself.
Step 7:
