Shelf Made Shed
Intro: Shelf Made Shed
I have not found any other Instructable or online guide that suggests this method of building .
I think that this is an amazing new way to build a shed using shelving as the core, which saves a lot of work and money.
STEP 1: The Need
When I retired I had to move out of my offices. That meant I suddenly had to find a home for 20 years of accumulated stuff.
Not only that, but I had to do it fast and at the lowest possible cost.
I looked at using local storage facilities or buying a big shed, but both were way out of my budget.
STEP 2: The Idea
I had all the plastic shelving from my now vacated premises.... but no room or shed to put the shelving in.
Then I had that amazing AHA moment. I could use the shelving as the very core of a new building.
I was not sure that the shelving would be strong enough and firm enough to support the structure, so I needed to do a trial. For that I cleared a suitable area at the back of the garden , and laid them out.
STEP 3: Preparation
The layout clearly showed that the shelving would fit neatly into the space. It was strong and I was pleased to confirm that they would be a great basis for a building.
Unfortunately, It also showed that I would need to do a lot of preparatory hacking.
STEP 4: How to Get It All Together?
Ok... so I would have a core, but I needed to hold it all together and find the cheapest components that would protect the contents from the elements.
I considered just throwing a tarp' over the lot, but that was not really going to give me the protection needed.
I experimented and came up with the idea of strapping the shelving together with good old Zip ties. This was very effective in stabilising the groups of shelves but then I needed to attach a frame to hold some form of cladding, and support a roof.
I had a large number of thin interior cladding boards which I decided could be screwed onto the outside junctions of the shelves.
This would provide further strengthening to the core and give me the height I needed to construct the roof.
I originally thought of covering the outside with plywood or even OSB board, but the cost was too high...Then on an expedition to my local Wickes I saw a plastic sheet material similar to Correx. The sheeting is designed to protect floors during building work. It is VERY cheap at around £4 per 8ft by 4ft sheet. This could be my rain-proof, rot-proof cladding.
The final requirement was for the roof. Since I did not want windows taking up valuable storage space , I decided that clear corrugated PVC roof panels would be the best way to go.
STEP 5: Starting the Build
I was lucky to have pavings already in place and so I just covered them with a tough plastic sheet to act as a damp-proof membrane. My wife and I assembled all the shelves and then realised that we would not have access to the end, once everything was in place.
Consequently the far end was first zip tied together, the battens screwed in and cladding fastened on. Then the pre-assembled end was pushed into place.
STEP 6: The Cladding
The sheets were simply laid over the backs of the shelves and screwed to the battens. Next a knife was used to cut the sheets to size.
All screws were inserted in little plastic covers so that they would be waterproof. At the ends another vertical layer was added for extra protection, to cover the open ends and to make it look better.
STEP 7: The Door
I had an old door frame and door, which was way too good for the job, but was the cheapest solution. I placed it into the gap. Then secured it direct to the plastic shelving. At one side I needed to cut filling blocks which I reinforced with metal brackets.
Of course everything had to be constantly checked for level and verticality.
STEP 8: The Roof
I decided that a shallow 10 degree slope would be enough to allow rain to drain, and would maximise the internal storage height.
At first I tried to cut the lengths of PVC roofing with a jig-saw and a fine toothed blade but that was an epic fail, smashing the plastic AND the blade. Next I tried using a cutting disc on an angle grinder which is DEFINITELY the best way to do that job.
I used the wavy foam inserts that are sold along with the sheets, for extra support and sealing.
The little plastic covers were also used to prevent water leaking into the structure.
STEP 9: The Finished Project
I was very pleased with the result. It is a great shed made from shelving and perfectly strong and dry.
I estimate that it has given me over 100 sq ft of storage.
I have subsequently added a door surround and a bottom board to neaten appearance.
Since using the plastic shelving as the structural support for the shed, I have been looking at other shelving systems.
I am sure that using metal, heavy duty shelving would produce an even stronger permanent structure. It could be clad with the plastic or with exterior quality ply and maybe then rendered to produce a superb building.
I definitely recommend that you try such methods yourselves.
49 Comments
TeresaM79 1 year ago
el_mag 2 years ago
How has it fared over time and do you get condensation?
How did you join the sheets to each other eg just butt jointed or overlapped & how did you waterproof the joints & the corners?
Thanks
Gregarious 2 years ago
There are many times when a shed will also need racking and since I had several from closing my business I decided to use them as the core supports. This has worked out extremely well. The other unique element was the use of the very cheap plastic sheets that are designed for covering floors during building work.
I have since used these all over the garden to cover and protect and as roofing too. They do not fade and stay waterproof. II have also found them to be a cheap effective dampproof sheeting and also used them as shuttering in forms for concrete casting or laying.
It is best not to attach them with screws or staples. I did use screws which I encapsulated in the little washers with caps that hide the screws. In some places, I also covered them with duct tape (and in yet other places hot melt glue) but I now think that plastic bonding glue is best. They can be glued to wooden uprights which do not need to be super thick or strong since they are only providing an anchor point.
(It may also be possible to use the joining strips designed for conservatory roofs, but they cost as much as the sheets!)
Slight overlapping provides extra security and rigidity. The corners were simply covered with a strip of the material folded into a 90 degree covering corner piece.
There has been no leakage from the corrugated plastic roofing but there is sometimes condensation. This has either rolled down the angled sheets emerging at the back or has evaporated later. I did think that I might have needed to put something under the roof to avoid condensation but in the end, it has not been an issue.
The one complaint that I have had is that it does not look very attractive. This summer I plan to cover the front with a cheap feather board. It has been suggested that he sheets could be painted and might be made more attractive by the use of stencils or even 'graffiti' designs. I do have a plan to build a Wendy house for my granddaughter using them.
I hope this is helpful. Good luck with your own project.
Please do upload images of the completed project.
SabinaCowan 7 years ago
thinking about making a chicken coup.
Deltic 7 years ago
B*ll*cks! - I just gave away 5 of these shelving units - I'll never make a comedian; my timing sucks! Great idea btw.
jam1701 8 years ago
can you provide more info on the material that you used for the walls ?
wayne.ennisthompson 8 years ago
we call it corflute in Australia
http://www.corex.net.au/products/view/id:1/title:Corflute+Sheet
Gregarious 8 years ago
Hi...thanks for asking.
As I say in the 'ible , I got it from Wickes who I believe operate in the US as well as the UK. It is branded as Antinox. I have also used it as a great roofing material on another garden shed.
rledsom 8 years ago
Thanks for your compliment.
As I say, the plastic sheets and linking materials are cheap, since the shed is primarily supported by the shelving, (that I already had).
If you need to buy shelving then that could be a major cost component.
My concept is the reverse of the usual method whereby you build a shed then buy or build shelving to put into it.
It is overall a cost effective method of having both a shed AND shelving.
Using just the plastic sheet material with traditional 2x4s and cross members would still save money over cladding with ply, OSB or feather boards.
If you just want to build a regular standard shed then the traditional method is perhaps the cheapest way to build.
I mentioned the product in another reply and the name Antinox.
It is very similar to Correx the fluted plastic sheeting that is often used for signs.
If you (or anyone) wants to read up on it then this is the link is to the place I bought it:
http://www.wickes.co.uk/Swiftec-Antinox-Surface-Protection-2-4-x-1-2-x-2mm/p/118670
I searched for a source in the USA but have not found one. I thought that Wickes still operated in the states, as I have visited a store there in the past, but I have not found any addresses.
Hope this helps. Cheers.
mbusby 8 years ago
Nice solution for your area. Just a quick point about cable ties. Use solid colour ones as the clear or white degrade very quickly when exposed to direct sunlight. I know you are in the UK and you don't have the same sort of sun exposure as I do in northern Queensland but clear cable ties will fail here within 6 months black or any other solid colour will hang in there for 2 to 3 years, but they will all fail eventually.
PamG10 8 years ago
I have to agree. This would never stand up to the sun in Oz, as plastic quickly perishes as the roof on this shed will eventually.I also don't see this standing up to the storm that we have here either.
Thanks for the contributions above which I am sure friends in differing climates will take note of.
Here in the North of England, we have just had a great storm, with 80 mph winds and near horizontal heavy rain. My poor little shed remained unaffected and there was no ingress of water. That was not quite the same story with my concrete garage that has a solid roof and DID let water in.
Please all note that I have never said, nor would I say, that my method is suitable for every weather condition or location.
My basic idea it that instead of building a frame then putting in shelves, it is possible to use shelving as the frame. That shelving could be super strong metal or the simple plastic as I used. The end result is perfect, but only if you wanted shelving in your shed. You should then use whatever is best in your area for covering the sides and roof.
With regard to the discussions regarding the cladding and roof then I would simply say that everyone just needs to use their local knowledge and choose the best materials that match their budget.
I went for really cheap materials because I had to have a waterproof storage shed fast and cheap. Having said that I can confirm that the fluted plastic sheet cladding is performing far better than past projects where I used marine ply or feather boards.
As for the roof and my use of the corrugated PVC I can also confirm that where I have used it elsewhere in my garden it has gone opaque, but is still doing the job. That is after up to 10 years and a lot of UV exposure.
Of course different climates and locales will produce their own results.
The ones in my shed are not really exposed to sunlight and in any event the main reason for using them was during the early construction to keep everything together. Once the battens were on and everything screwed together they were not really needed.
However despite our 'inferior' weather, I will certainly heed you warning and will not use them in mission critical projects in future.
Thanks for the info.
PamG10 8 years ago
NO one said that the weather in the UK was inferior but rather that Australia being closer to the sun in summer is far too punishing. Were this to be made of steel it would hold up brilliantly. The poor attitude is your own dear author, whilst you may believe that down under is a paradise, it is in fact very punishing.
BethanyH4 8 years ago
Does it get pretty warm in there? I like the design, but I wonder about ventilation.
We have had some pretty hot sunny days after it was built and it was not at all bad. I have not taken measurements but I did pop in specifically to see how hot it got since it has black plastic sheeting.
It was just as you would expect any outhouse or shed to be.
I too was worried about ventilation since I was concerned that the door would not close or if I shut I fast the air pressure would bust the roof off!
For that reason I have left a few gaps under the roof which are still waterproof but do let air in/out.
I keep a lot of documents and art materials in there and so far they are not adversely affected.
I will keep checking though, since we have not had a frost yet.
Cheers.
dmagryta124 8 years ago
This was designed to be a waterproof safe place for me to store a range of items. I certainly would not move in or rent it out as accommodation.
There are many other materials that you can use to give better insulation if required. The triple walled polycarbonate sheeting used for conservatories would be pretty good for the roof...if a lot more expensive,
The PVC sheeting does not yellow but it does go more opaque.
