Introduction: Shell Button Choker
Just in time for summer, a lovely and unique repurposing of a vintage button.
Step 1: Shell Button Choker
- I came across some LARGE vintage abalone shell buttons recently, too beautiful to relegate to the trash, but a bit too large to use on any clothing. A cousin saw them, and raved how they'd be perfect to bring out the blue in her eyes.
Materials List:
1 - Large shell button (I'm talking the size of a silver dollar or better.)
1 - Velvet choker (I chose a soft blue.)
Thread (Button cord is best, very strong. I only had black, but it got covered later.)
Strong needle for button cord
Jewelers Glue (Aleene's is good.)
5 - Small glass flower beads (I chose pink, to offset the blue shell.)
5 - Tiny glass beads (Green, to complement the pink and blue.)
Silver toggle and chain
Tools (Pliers, cutters, thread snips.)
Toggle setup: My choker had a standard, ugly toggle. I removed it, and added a silver heart-shaped toggle, along with a dragonfly charm, my signature on all my jewelry. I find it is far easier to do this step first, before any other work.
Step 1
Determine the orientation of your button - most abalone has a pattern that just LOOKS better if rotated a certain way.
Step 2
Center the button on the choker. This is an important step, especially if you're using a velvet choker - it can be a touch difficult to steam the holes closed if you sew it on and need to move it.
Step 3
Attach securely with thread, dab ends with a bit of glue after knotting. Let dry for thirty minutes. (Trust me on this one, you cannot get the glue off of velvet. Ack!)
Step 4
Once the glue is dried, flip 'er back over. I wanted my beads to look natural, so I played around with the positioning for a bit. I found an arrangement that didn't appear too awfully static, so I used a head pin to dot glue on the button, letting it get tacky. At the same time, I used needle-nosed pliers to allow access to the back of the flower beads, and dotted them, one at a time, with glue. I then gently set the beads on the button, pressed firmly with my fingertip, and let dry. When all the flower beads were set, I used my head pin to go around the edges of the flower beads, and ensure they were well glued. I then dotted the green glass beads with glue, pressed firmly, and followed up with extra glue as with the flower beads. LET DRY OVERNIGHT.
Step 6
Enjoy!!! As my buttons are large, somewhat thick, and the choker thin, it is essential that this is worn TIGHT, lest it sags and causes the choker to flip over.
