Introduction: Shell Earrings
Broken Shell Earrings
Step 1: You Will Need:
-8 broken shell beads (i think you can get them from bead work shops or craft shops)
-16 tiny beads
-2 head pins
-2 ear hooks
-2 tiny loops (to connect the ear hook to the earring)
-Also you will need 2 pairs of plyers
-16 tiny beads
-2 head pins
-2 ear hooks
Step 2: To Get Us Started:
place 2 smaller beads on the head pin and then a shell bead
Step 3: Step 3:
keep adding 2 smaller beads and then a shell bead
Step 4: Step 4:
When you get to this stage its time to start adding the loop that will attach the ear hook
Step 5: Time to Make the Loop
This is probably the most challenging part of making the earnings but if you are familiar with jewelry making you wont find it difficult.By using a pair of round nose plyers you will be able to bend the wire at the top of the head pin to make small loop.
Step 6: Connecting the Earring to the Ear Hook:
Use the small loop to connect the earring to the ear hook.Using two pairs of plyres bend the loop slightly out of place,this will enable you to insert both the hook and the earring into the loop.Then use the two plyers again to bend the loop back into shape.
Step 7: Finished
Do this again to complete a pair of earrings!:)
