Introduction: Ultra Strong Tape Bonding Trick!
There a easy and amazingly durable fix!
This trick is great for tarp shelter repair!
Please rate me! :)
Step 1: You Will Need:
Gorilla tape ( tough&wide if available)
Acetone
Knife
scuff scotch-brite pad
paper towel
Heat gun or hair dryer"Genuine idea!" please rate
WARNING!
A well ventilated or open area
Only recommend to use heat on Gorilla Tape! Other will be damage!
Acetone
Knife
paper towel
WARNING!
Step 2:
Before doing anything, try some acetone on a non visible area for testing...
Nothing wierd happen? OK!
Next the thinking part! Think you will have to overlap the tape at least 3" all around the damaged area.
Step 3:
NOW! Clean the surface and brush off hard with acetone all the area where the tape would be. Wipe and make sure it well clean before applying Gorilla Tape.
Step 4:
Now install the tape PERFECTLY flat.
Repeated these step on the other side of the tarp.
You can also add strength on friction area.
Step 5:
Heat the installed tape the hottest your skin can handle. About 50°C\120°F
DO NOT OVERHEAT OR MELT THE TARP (you can wear glove)
Now strongly rub the tape into the surface and leave no air bubble between. This will help achieve a better bond.
Now it will be good for another winter!
