Introduction: Shift Register + LED Array & Arduino: 5 Examples
I know that there are many examples on this topic however I wanted to make a simple and compact instructable with five examples:
1)One way shift
2)Two way shift
3)Two way shift with increasing speed
4)Random LED
5)Random Fill
Arduino Uno (original or any clone), male-male jumper cables, 8 LEDs, 8 33o Ohm Resistors, Breadboard, Arduino IDE
Step 1: Circuit Setup
The connections:
-All LEDs through 330 Ohm resistors and to 8 output pins of the 74HC595 shift register
-Shift Register Vcc pin to Vcc of Arduino
-Shift Register GND pin to GND pin of Arduino
-SRCLR active low output to Vcc
-OE active low output to GND
-SER input of Shift Register to Pin 12 of Arduino
-RCLK pin of the Shift Register to Pin 10 of Arduino
-SRCLK pin of the Shift Register to Pin 11 of Arduino
Step 2: 5 Examples:
Use the following code to shift in one way:
https://github.com/selimg76/microcontroller/blob/m...
Use the following code to shift back and forth:
Use the following code to shift back and forth with increasing speed:
Use the following code to make a random LED on:
Use the following code to fill all LEDs randomly:
If you like the content please subscribe to my YouTube channel for similar tutorials and projects.
https://www.youtube.com/c/drselim
Thank you
