Introduction: Shiratama Eyeball Drinks!
Shiratama is a Japanese snack that translates to 'sweet rice dumpling'. I live in Japan and these are very popular.
They aren't too sweet, so keep that in mind if you give my recipe a try. Your kids might throw them right out the window! They taste almost like Mochi (sticky rice) and some people might consider them bland.
My Shiratama have a subtle sweetness and elastic-bouncy texture. They can be made sweeter with toppings like jam or honey.
Step 1: The Ingredients
These are extremely easy to make!
You only need Shiratama flour, soft tofu and food coloring. Shiratama flour is available on Amazon or at Walmart and Target. It's also called Shiratamako or Shiratama powder. Be careful, because there's a difference between Shiratama flour, Mochi flour and glutinous rice flour. These are similar, but can't substitute each other.
Normal Shiratama is just the Shiratama flour and water, but I use tofu, because it keeps the Shiratama softer much longer. They turn hard quick with water.
My recipe is:
400 grams Shiratama flour
560 grams soft tofu
A smaller batch:
100 grams Shiratama flour
130-140 grams soft tofu
Step 2: Making the Shiratama Mix
You're going to
1. Put the Shiratama flour in a bowl and then place on the soft tofu.
2. Mix with your fingers. No utensils required.
3. Form a ball.
4. Separate pinches of dough to add color to.
Step 3: Adding Food Coloring
You can use powder or liquid food coloring for this.
It's best to roll out the eyeballs, irises and pupils before adding the color so you have an exact count.
After everything is rolled into little balls or 'dango' in Japanese, you can combine them into iris and pupil balls to color.
*Wear gloves when you color the Shiratama. Some food coloring is difficult to wash off.
Step 4: The Eyeballs
These are the eyeballs.
Step 5: The Iris
Once the Shiratama are dyed, you can take off your gloves to make the eyeballs.
1. Flatten out an iris in the palm of your hand using a finger.
2. Place the flat iris on the eyeball.
3. Place the pupil on the iris.
4. Gently press and roll all of the pieces together to make an eyeball.
Step 6: Eyeballs!
Step 7: Cook Your Eyeballs
1. Prepare a large bowl of ice water to put you Shiratama in once cooked.
1. Bring a large pot of water to a boil.
2. Gently drop the Shiratama into the boiling water. All of the Shiratama will sink to the bottom of the pot.
3. When all of the Shiratama are floating, wait 2 minutes.
4. Strain the Shiratama and then transfer them to the ice water.
Once they are firm and not hot, you can freeze them or eat them.
Step 8: Freezing Them
Freeze them in away that they're not touching. This is very important!
Step 9: Use Frozen Shiratama As Ice Cubes!
Step 10: Drinks!
You can use these in mocktails or cocktails!
Kids drink
Add three frozen eyeballs to a wine glass, fill with cider or a clear soft drink and add a few drops of grenadine and one drop of red liquid food coloring.
Adult drink
Do the same as the kids drink, but dump in vodka!
Blueberries compliment these Shiratama well too!
Runner Up in the
Halloween Contest 2018
15 Comments
Question 1 year ago on Step 3
OK, one more quick question. How did you color the pupils black? There's no black food coloring at my supermarket... Did you something other than regular food coloring?
Answer 1 year ago
I used black food coloring. I just checked and it's on Amazon. I like the powder type, because a little goes a long way and the colors are vivid.
Question 1 year ago on Step 7
Can the eyeballs be made ahead and boiled later--like saved in the fridge for 1 or 2 days, or would they get funky--water leaching out of the tofu and making them dissolve or lose shape or something...?
Answer 1 year ago
Hey Tana! I wish, but the dough will dry out. Once the balls are rolled, you have about 30 minutes until they start to dry out.
Reply 1 year ago
Thank you so much for your quick response, and sorry for my own late reply. Bummer that they don't keep for later boiling, but, I'll just go ahead and try making a batch with all the steps at once and freezing for later as you suggested.
5 years ago
The colour combination of the drink is great!
Reply 5 years ago
Thank you very much!
5 years ago
WoW thanks!
Excellent post and idea. Very nicely laid out with great pics and step-by-step easy instructions. Great job, you’ve got my vote. I can’t wait to try these. Do they easily float inside the glass sideways so you can see the iris, or does is sink or float?
Reply 5 years ago
Thank you! They sink and you can adjust them to sit in any position.
The texture and weight of Shiratama is perfect for this. Smaller shiratama are even usually added to sundeas/parfait in Japan too.
Question 5 years ago on Step 10
why does this matter also i live in australia i can get tofu can i use plain flour wheat there's a difference between Shiratama flour, Mochi flour and glutinous rice flour. These are similar, but can't substitute each other.
Answer 5 years ago
The rice flours I listed are processed differently and have completely different textures and tastes. If you make Shiratama with mochi flour, the balls will be grainy and gooey. Use rice flour and they'll be sticky and chewy. You definitely shouldn't use wheat/white flour. It just wouldn't work. It would be like making a pizza or ravioli using Shiratama flour. They'd turn out gross.
5 years ago
Those look like a fun addition to your drink! I like that they sink :)
Reply 5 years ago
Thank you very much! Me too about the sinking. These things have some weight to them. :)
5 years ago
YES! These are fantastic.
Reply 5 years ago
Thank you very much! I'm a huge Shiratama fan! :)
