Shishi-odoshi With PVC
Intro: Shishi-odoshi With PVC
Never thought these unused PVC materials will come up with an ideal waterfall fountain.
Materials needed for this masterpiece are :
- PVC pipe
- Foamboard
- PVC Casing
- Plastic Tray
- Aquarium Pipe
- 3W Submersible Pump
- Spray Paint
- Drill
- Hot Glue
- Artificial Plants
- Stones
STEP 1: The Base With Stand
Make the structure on a base for water storage with support.
For me, the plastic tray was the best option for this.
Attach the PVC on both sides of the tray refer images.
Attach PVC casing on the PVC pipes as shown in the images.
Watch the full making on our YouTube Channel :
STEP 2: The Small Water Tank
Now need a water chamber from where the water will get spread, so I took a 5inch PVC.
Make a hole on the PVC and connect 2 small PVC pipe. Refer Images
A foam board needs to be attached and glued
Make another hole and connect an L-Joint with it.
Then attach it on the middle of the 1st casing.
Take an Aquarium pipe and connect it with L-joint in the water chamber.
STEP 3: The PVC Pipes
Connect a 3W Submersible pump with the pipe.
Cut 5 pcs of PVC pipes and give a slanting shape refer images
Colour them with spray paint. (optional)
Then attach the PVC pcs on the casings as shown in the images.
STEP 4: The ODC Making
Now take a small PVC pipe
Make a small hole on the middle of the pipe and shape it with the drill.
I got this plastic stand to hold the pipe.
Our shishi-odoshi is now ready.
Now place it on the tray.
