Introduction: ShockFang – Simple DIY Noise Machine (Golden Glass + Aluminum + Rubber Bands)
About: Hey there I'm priyanshu2206 and here to just show some energy by making something different with diy arts & projects.
ShockFang is a simple DIY noise-making instrument shaped like an electric guitar.
It is made using gold acrylic (gold glass), an aluminum rod, screws, and rubber bands
The build is easy, the look is cool, and the sound is unique.
Gold acrylic sheet
Aluminum rod
Rubber bands
Screws & nuts
Strong glue
Small wooden or acrylic block
Sandpaper
✅ Tools
Drill
Acrylic cutter / jigsaw
Screwdriver
Marker + ruler
Safety gear
Step 1: Cut the Glass
Draw a simple electric-guitar shape on the gold acrylic sheet.
Cut slowly using a cutter or jigsaw.
Sand all edges until smooth.
Step 2: Add Aluminium Rod
Paste the aluminum rod across the middle of the body.
This works as the bridge and helps create louder vibration.
Make sure the rod is straight.
Step 3: Drill Screws
Drill Screw in aluminum rod for rubber band
Note :
Step 4: Add Rubber Bands(strings)
Stretch 3–5 rubber bands from the neck area to the aluminum rod.
Adjust the tension until the bands sound clean when plucked.
Thin bands = high sound
Thick bands = deep sound
Step 5: Sound Test and Final Look
Clean the gold acrylic
Tighten all screws
Smooth all edges
Your ShockFang will now look like a mini electric-style noise machine.
