Introduction: Shooting Stick
For this project I used a 5 section elasticated tent pole.
The Velcro straps were taken from an old pair of knee pads.
The rubber end caps from drill tubes.
Step 1: The Build
It didn't take much to make this, all you need is.
1 x 5 section tent pole
1 x roll of duct tape
1 x 18" inches of Para-cord
2 x Velcro straps
6 x rubber end caps
Some Green and Black paint if desired.
2 x Velcro straps
6 x rubber end caps
Step 2: The Bits
Remove one section of the tent pole and cut this in half.
Use the metal pole joints on the cut legs as these will become extensions
for the shooting stick, when you spread it to a wide angle stance.
Step 3: The Joints
Pull the poles apart by about 6 inches and use duct tape to hold the elastic tight .
Push the end caps on to the poles.
Using the Para-Cord make a cradle with a Cobra stitch.
I also used some acrylic paint to Camo the Stick.
Step 4: The Result
Now you have a stable platform for your Airsoft targeting range.
