Introduction: Shopping Cart Chair
Turn a shopping cart into a comfortable stylish wheelchair!
You'll be amazed what a nice chair you end up with.
As seen in Make Magazine volume 07
by Tim Anderson, photos by Jen Munch.
Now on Know How! Click on the steps above for more details.
Do you like this Instructable? Digg it! Then check out episodes one, three, four, five, six, and
seven!
seven!
Step 1: Find a Cart
The shopping cart. Visitors to the United States are astounded by our shopping carts, which are the largest in the world. Also amazing is their abundance miles from the stores from which they came. No homeless person will ever want for a shopping cart.
The best selection of shopping carts will be found near a "redemption center" where homeless people get paid for recycled soft drink containers.
Step 2: Through Destruction Comes Creation
Look for a shopping cart that really wants to be a chair. You won't have to cut or bend much to release the inner chair.
Let's get started. Pound, twist, and pull out the retaining rods and remove the front bumpers.
Save them. One can be used later to cover the front edge of the seat
Step 3: Plan Ahead
Plan the cuts you will make in the wire basket. Blue tape marks where the cuts will be made.
Iron origami magic will make nice arms from those weird projections. This particular cart had very high sides,
so I thought I'd try a new style of arm bending. I've been making these things for a couple of decades, but there is always something new to try.
Step 4: Cut It Up
I'm using a sawzall to cut along the lines. A hacksaw, bolt cutter or angle grinder work well also.
The right chair design will require few cuts. The chair is already there. You're just releasing it.
Step 5: (Neat Trick)
Here's how to keep your power cord from pulling out of the extension cord.
Step 6: Bend the Arms
Clamp a couple of boards to make the crease of the bend happen where you want it.
This was a tricky diagonal bend and it took a lot of leverage from the long sticks to make it happen.
Note that bending the metal work-hardens it. It's very difficult to change if you bend it wrong.
Step 7: Curve the Arms
For the next bend I made a tool from pipes and bolted it onto the protruding arm piece.
Step 8: Clean It Up
Clamp a couple of boards on the front edge of the chair and bend it down.
File all of the burrs off the ends of the cut wires.
Step 9: Finish the Front.
Step 10: Alternative Method of Finishing the Front Edge
Carve the inner projections of the bumper so they'll fit over the wire and
slide the retaining rod through the holes.
Step 11: And Now You Have a Chair.
Two different chairs, two different styles. Don't leave them outside though, because they will rust.
