Introduction: Shorten Power Cable
Take a standard figure 8 cable or standard kettle lead.
Step 1: Cutting
cut cable to length that you want
Step 2: Strip Cables Down
I used a cable strippers but you could use a knife or any sharp instrament
Step 3:
Put some cable shrink around cable and then twist cable together. n.b: all colours should match up.
Step 4:
Wrap cables up seperatly and then when cables are completly isolated put togher and rap them up again.
Step 5:
Pull down shrink over taped up end and heat i used a ligher but you can use anything that is hot (n.b) to hot will melt shrink cable and also might dapage cable.
Step 6: Finaly
You have a shorted cable that makes life bit easier in your bag and on the wall.
