Introduction: Shotgun Shell Pen Holder
This tutorial will show you how to make a shotgun shell pen holder.
Step 1: What You Need
1. Two empty shotgun shells
2. A empty 30-6 shell
3. Hot glue gun
4. Extra glue if needed
5. Scissors
6. Pens
7. Any kind of decoration (optional, hides the glue)
3. Hot glue gun
5. Scissors
6. Pens
Step 2: Dots
Draw a dot right above the brass part of the shotgun shell on both with a pen.
Step 3: Small Hole
Poke a small starter hole with the scissors at the dot.
Step 4: Slice
Cut along the brass until it is in half. (look at the pic)
Step 5: Cut Up the Middle
Slice up the middle exactly in the center of the cut area by the brass. Then bend it open like the picture. Do the exact same thing with the other shell.
Step 6: Gluing
Glue along the cut part on both sides and stick the two together.
Step 7: Add Your 30-6 Shell
Put glue along the top brass part and secure your shell. The best way to put it up is to tack it to a board or wall.
Step 8: Decorate
Put on something from a necklace on it, or come up with something on your own. This will cover the glue.
Step 9: Finished
Put in your pens and you're done.
