Introduction: Show How to Build a Pyramid Through the Tinkercad Platform
This should be the final and expected result in the construction of the pyramid
through this page we will carry out this work https://www.tinkercad.com
Step 1:
1. First we are going to delimit the area in which we are going to build the pyramid, choosing a color and making a square with which we are going to make the exterior of the pyramid. In the toolbar located on the right side you can see different shapes and tools; so we choose the one with a square, we make a completely flat one for the base and another of a moderate size to use as a building block
Step 2:
2. For convenience; I suggest doing the interior design of the pyramid before beginning the exterior construction process. So we use different tools from the toolbar, to create the rooms; the royal rooms, both the king's and queen's and the treasure room and the creation of the conduit leading to the labyrinth. We will use the tool that is like a striped gray cube to cut out a piece of the base of the pyramid for the entrance to the maze; we are creating an ascending path to create a union for the exits and entrances of the king and queen rooms; using the cube shape to make the paths by stretching them and cube and pyramid for the creation of the rooms.
Step 3:
3. Next, we will go with the creation of the underground labyrinth, the main thing is to use the way to enlarge it and accommodate it so that there is an interior hole with the help of the gray cylinder; now to create the labyrinthine part we will use the cylinder again and arrange it in such a way that it resembles a wall shape and then we use the tinketcad tool to copy the same shape and use it consecutively until we get it to resemble a maze.
Step 4:
4. We will give way to continue the construction of the pyramid, using the copy and paste tool; We used one of the paintings from the base of the pyramid, we copied it and we began to make the layers of the pyramid, in order to close the rooms of the king and queen and give shape to the pyramid. .
Step 5:
5. With this we are done, thanks for watching
