Introduction: Side Table - Pallet Wood
Tools and Materials Needed:
Sand paper
Screw driver and drill
Pallet wood
Measuring tape
Saw (table/circular/jig-either)
Hot glue gun
Brads
Screws
Stain
Polyurethane
Paint brush
Step 1: Sort, Select and Cut to Size
I sorted out all my pallet wood and selected 6 pieces that were similar in appearance (color/type), width (2.5") and thickness (1/2").
Then using a saw I cut the excess, to make each piece 30" long.
Then I cut the 6 pieces in half.
I sorted the best 6 pieces for the top part of the shelf and the remainder for the bottom shelf.
Step 2: Assembly, Stain and Seal
I selected 2ea 15" pieces of wood and split them length wise, this gave me 4ea pieces, 15" long x 1/2" thick x 1-1/4" wide.
I leveled, hot glued and nailed these strips on either end of the top/bottom 6 shelf pieces.
Then I predrilled holes and screwed the leg posts onto all four corners of the shelves.
Once the table was assembled I hand sanded all visible surfaces. First with 80grit and then 220grit sand paper.
The sanded surfaces were then wiped with a clean rag and stained.
After wiping the excess stain off, I let the table sit for 4 hours before applying clear high gloss polyurethane sealer.
After 1hour I sanded the first coat and reapplied the polyurethane. That's it.
The table size is 15" x 15" x 20"
NOTE: If I had to do this again, I would sand, stain and seal all pieces before assembly.
