Introduction: Sigfox Doorbell Posting Message on Slack
It all came from a challenge made by Nicolas Lesconnec on Twitter to add Sigfox connectivity to Konstantin Dimitrov's great project: Arduino Capacitive Sensor In less Than 2 Minutes.
So, I decided to give it a go!
But it is useless to just add connectivity to a project. Hopefully (or not) our door broke yesterday on the 4th floor, thus, I decided to make a doorbell that posts a message on Slack.
The base of the project is the same than the Arduino Capacitive Sensor In Less Than 2 Minutes, I just changed from an Arduino to an Akeru board, which has the same Atmega processor but has the Sigfox module included.
Step 1: Hardware
You just need:
1 x Akeru board
1 x 1M resistor
1 x Coin (or any conductive material)
1 x LED
4 x Jumpers
1 x Cardboard box (I used a Sparkfun Kit's box)
Just plug the 1M resistor between the D2 and D8 pins
Step 2: Arduino Code
First, you need to download the following library and import them under the Arduino's library repository:
Now create a new sketch and copy/past or clone the code:
https://github.com/luisomoreau/sigfox_doorbell
#include <Akeru.h>
#include <CapacitiveSensor.h>
// TD1208 Sigfox module IO definition
/* Snootlab device | TX | RX
Akeru | D4 | D5
Akene | D5 | D4
Breakout | your pick */
#define TX 4
#define RX 5
// Sigfox instance management
Akeru akeru(RX, TX);
//Capacitive sensor
CapacitiveSensor cs = CapacitiveSensor(2,8); // 1M resistor between pins 2 & 8, pin 8 is sensor pin, add a wire and or foil
//Global variable
bool flag = true;
void setup()
cs.set_CS_AutocaL_Millis(0xFFFFFFFF);// turn off autocalibrate on channel 1 - just as an example
//Serial.begin(9600);
pinMode(7,OUTPUT);
//Serial.println("Starting...");
if (!akeru.begin())
//Serial.println("TD1208 KO");
while(1);
}else{
//Serial.println("Ready!!");
void loop()
long sensor = cs.capacitiveSensor(50);
//Serial.println(sensor1); // print sensor output
if(sensor >= 1000)
digitalWrite(7,HIGH);
if(flag){
sendMessage();
else{
digitalWrite(7,LOW);
void sendMessage(){
flag = false;
//Serial.println("Sending...");
if (akeru.sendPayload("01"))
//Serial.println("Message sent !");
delay(1000);
flag = true;
You can try to run the code, every time the coin is touched, it will trigger a Sigfox message.
Be careful to the duty cycle limit. This depends on your region's regulation.
Learn more on http://makers.sigfox.com/
Step 3: Connect Sigfox and Slack
Activate your device
If you don't know how to activate your device, I wrote a small tutorial few month ago on http://blog.sigfox.com/activate-dev-kits/
Create a Slack WebHook
In order to post your message on slack, go to your slack's team and create a new incoming WebHook:
https://[your-team].slack.com/apps or search for Incoming WebHook
Click on "Create a new configuration"
Follow the form and copy the given webhook link
Create a Sigfox custom callback
Now go to your device type in Sigfox Backend (https://backend.sigfox.com) and click on Callbacks.
Click on "New"
Past the incoming webhook and add your JSON:
"text": "Hey!! Someone is stuck at the door... could anyone open the 4th floor door? thank you :)"
}Now every time a sigfox message is sent, a message will be post by your Slack bot.
Step 4: Challenge Accepted
I would be glad to answer your question.
Thank you for your attention.
