Silence a Mouse's Scrollwheel
Intro: Silence a Mouse's Scrollwheel
Whether it's at the office, or the home, Any (well, most) computer has a mouse to go with it. With every mouse, comes that handy scroll wheel wich allows you to, almost effortlessly, scroll through documents, websites, and games.
Although handy, after a short period of time, that constant clicking can become the bane of one's existence when working on a project or playing a game for more than 5 minutes. Luckily, it isn't difficult to get rid of that incessant clicking in most cases, and doesn't affect the performance of the mouse in a negative way. In fact, it can actually enhance the ease of the scroll wheel
STEP 1: What You'll Need
A mouse to silence
A phillips head screwdriver
Needle nose pliers (not always needed, not shown)
STEP 2: Crack It Open
Most mice only have one screw to contend with, so taking it apart is incredibly easy. The screwdriver i had pictured was the tiniest bit too big (1/4" dia.) so i used the one in my leatherman multi-tool.
STEP 3: The Insides
Since i knew that non-optical mice are almost extinct, i decided to take apart the DELL mice along with a broken optical one i had laying around. They come apart the exact same way, so just apply the previous step to both kinds of mice.
Once you've gotten the mouse open, take a quick look around to locate your scroll wheel, it should be glaringly obvious. If you have an optical mouse, just pull it up out of its bracket, making sure not to loose any of the springs attached to it. The wheel on the optical mouse can be pulled out by pulling it sideways from it's post. I've found it best to remove the PCB board from the plastic tray to do this. Most aren't screwed on, but some may be
Keep in mind that not all mice are exactly the same, so use your head when it comes to taking apart anything internal, or you may be purchasing a new mouse very soon.
Sorry for the shakiness of the second image, The lighting was bad and the auto focus wasn't working well because of it.
STEP 4: Silencing the Wheel
If you look carefully at one side of the scroll wheel in the non-optical mouse, you'll see that it's spoked. These spokes are the reason for the clicking. Now, instead of breaking all of the spokes out, we'll just take the little spring that hits each spoke as you rotate the wheel. If you have the Dell mouse that i'm using, you'll notice that there are two springs, one wraps around the post in the center of the wheel, and one is situated in the small plastic piece the wheel rotates around. Leave the first one alone, it aids in clicking the scroll wheel down. Just take the one that goes inside the wheel out. Once the spring is gone, just nest everything back together and slide the scroll wheel assembly back into place
If you have an optical mouse, notice that there are little metal arms that warp around the post that the axis of the wheel was through, you can either pry these open with a screwdriver, or use needle nose pliers (which i found easiest) to open the enough to pull the post away from the arms, and remove the black plastic wheel, and metal insert the makes contact with the grooves in the wheel. once you've taken the metal insert out, replace the black plastic wheel and use the pliers to put the metal arms back in place. After the post is secure again, push the wheel back where it was.
This will require some force, but don't go crazy, as we're dealing with small plastic parts.
STEP 5: Reassembly
Once the scroll wheel is back where it belongs, simply screw the casing back on, make sure not to break the tabs off in the process, as they help secure the front of the mouse to the bottom. Make sure the USB cable is where it belongs, so you don't cut it with the edges of the plastic.
I've noticed that the metal insert that we took out of the optical mouse acts as a spacer so that the scroll wheel doesn't make contact with the plastic. If your scroll wheel seems to be slower, look at the hole in the top and take some sandpaper to it if necessary.
5 Comments
farcrowd 5 months ago
Tearing it down, I found that the little spring pushing against the ridges inside the wheel was slapping back and forth in the plastic that it sits in - that's what was loud. I found some old grease, cleaned that out and added new, and then bent the spring sideways a little (the little looped part that sticks up and hits the wheel. It now sits sideways in the slot, still ratchets, and the spring can't slap back and forth enough to make it loud.
Someone else mentioned putting heat shrink tubing over the looped part of the spring - not a bad idea, just make sure the spring can still move up and down in the slot freely.
g3niuskxng 3 years ago
https://www.youtube.com/watch?v=JZ_bgRm1NoE&t=607s
or like the logitech mx master 3's silent scroll wheel @ 4:16
https://www.youtube.com/watch?v=LI6bKDVXpm0
because with these guys below who dud this or a variation of this the scroll wheel still makes a noise when they scroll hard/fast, would removing the notches remove sound completely?:
https://www.youtube.com/watch?v=Cwex45_9Kxg&t=274s
https://www.youtube.com/watch?v=aN7XHP6t9A0
thanks
jmeyer14 11 years ago
Reffner 12 years ago
Stormed Wolf 12 years ago
I only ran into the problem of the wheel not staying centered when the center button is one the side of the wheel, not underneath it. I tested out another optical mouse with the button underneath the wheel and there weren't any problems.
