Introduction: Silk Thread Card
this is one of the simple and comparatively less time consuming silk thread design card.
for making this card we need
- card
- silk thread
- needle
- scissors
- scale and pencil
- card
- silk thread
- needle
- scissors
- scale and pencil
Step 1: Drawing Basic Structure
roughly draw a vertical line dividing ur card into two halves on back side of visible/front side of card
similarly draw horizontal line dividing card into four parts
now behind the center point add a dot spacing 1 cm
put a dot next to the center spacing 1 cm
then add another dots from these new dots spacing 2.5 cm, refer photos
on vertical line draw one dot above and one below the center dot spacing 2 cm
then from these two dots add another two dots spacing 2.5 cms
now between new dot and 2.5 cms dot add total 9 points (11 points considering end points)
repeat this for all four sides
Step 2: Make Holes
now on these 11 dots (44 total) on each line make holes using needle.
Step 3: Make Thread Ready
on silk thread put a big knot on one side and pass other side through needle
Step 4: Go for It
now bring the needle trough the outer hole say hole one and put the needle back through the inner hole on the adjacent line say 1'
then bring needle through 2' and pass it through 2
then from 3 to 3'
continue doing this
then secure design by tying knot at the end
then from 3 to 3'
continue doing this
Step 5: The End
now repeat it on every side
finally you will get a diamond shaped design
you can write something in the middle space. name or wishes
