Introduction: Sim Racing Cockpit
These instructions are adapted from another Instructable by eyefail that can be viewed here. For an interactive model, download the SketchUp file. The file can be viewed using SketchUp for web.
Materials
- 3 - 1x2x8
- 1 - 1x4x4
- 8 - bolts 1/4"-2"
- 4 - nuts 1/4"
- 8 - washers 1/4"
- 4 - wingnuts 1/4"
- wood screws
- wood glue
Tools
- saw
- drill
- 1/4" drill bit
- drill bit for pilot holes
- jig saw (optional)
- router (optional)
- 7/16 wrench
- 7/16 socket
- clamps (optional)
Step 1: Cut Pieces
- Cut all pieces to length
- Drill holes for bolts with 1/4" drill bit
- Round the ends of the front and rear supports to allow rotation
Note: The height and length of the stand can be adjusted by moving the holes up or down the base and front supports.
Step 2: Assembly
- Assemble the base using 4' and 18" 1x2s with 2 screws at each joint. (use wood glue for a stronger joint.)
- Counter sink bolts in the 3" pieces
- Bolt front supports to 3" pieces
- Attach 3" pieces to the base with screws and wood glue
- Bolt rear supports to base.
- Bolt rear support to front support
- Attach the 16 1/2" 1x4 to the front supports
- Attach 14" (Top) piece to the 2-3 1/2" pieces
- Bolt the Top assembly to the front supports
