Introduction: Simon Says
Well, who doesn't like to play a game from time to time, and if a game helps your brain to train the memory that's even better. In this project i'm going to explain how you can make your own simon says.
· Arduino nano
· Arduino software
· Arduino code
· 9 * 220 ohm resistors
· 5x LED’S
· 5 x pushbuttons
· 1 x buzzer
· soldering iron and solder
· Kabels female to male
· Tinkercad account
· Een 3D printer
· Slicer programme
Step 1: What Do You Need for the Circuit
What do you need for the circuit:
· Arduino nano
· 9 x resistor
· 5 x LED’s
· 1 x buzzer
· 5x pushbuttons
· 1x breadboard
· threads
· arduino code / you get the modified code from me that i have dited
Step 2: Make the Circuit
1) Open tinkercad and go to cicuits and add a new circuit its the green button. Make the circuit exact like the picture and the code you get from me but the orginal code is from here: https://www.instructables.com/Arduino-Simple-Memo... I just made a few changes to have an extra led and pushbutton.
2) When you have the circuit, click on code it knows says that its on blocks but you don't need to have the blocks you need the text so click on blocks and then you see text click on that. Now put the text you see in the file place that in code of the arduino.
Step 3: Make the Box to Hide the Arduino
1) In tinkercad you can make 3D things so we are going to make a box and a lid to hide everything. Just go to the beginning were its said circuits, 3D Design, codeblocks.
2) Press 3D design and start with a red block an make it flat.
3) add the walls
4) Now make the holles so that the is room for the ports
5) Go and add a new 3D Design
6) Take an other red block and make it flat
7) Make the holes in the lid like on the picture
8) and if you feel the like to not make it i put the stl files in here
Step 4: Let's Make the End Product
When you make the end product, this is the end result!
