Introduction: Simple Arduino Laser Alarm
Parts:
Arduino (any board)
breadboard
laser receiver module
laser module
LED (any colour /color)
buzzer
jumper wires
Things you may want to add:
siren light
relay to control any thing
mirrors
Step 1: Wiring Up
First make sure your Arduino is turned OFF.
start with power to breadboard, laser module, laser receiver module, buzzer (short wire) and LED (short wire) plugged into ground / - / GND and 5v / +
Arduino inputs and outputs:
Pin 13 to "s" (signal) pin to the laser module
Pin 12 to the LED (long wire)
Pin 11 to the buzzer (long wire)
Step 2: Upload Code to the Arduino
Note: In the code I have written the alarm will sound for 3 seconds.
Plug your Arduino into your computer
select what type of board it is: Tools, Board,
the Arduinos COM port: Tools, serial port
and finally upload (ctrl-u)
Step 3: Thing Your May Want to Add
Siren light:
Take your light apart and remove all unneeded things inside and glue an LED in and plug the wires into were it was before. ______________________________________________________________________________________________
Relay:
Plug your relay into GND, 5v and Pin11 (you will need to add this into the code)
Mirrors:
Place the laser some were then place a mirror were the laser shines and do this till you like it, But make sure to aim it at the laser receiver module.
Step 4: Setup
Place the laser some were and aim it at the laser receiver module.
Turn on your Arduino and your done.
If you want to see my other laser alarm Instructable link is below:
