Simple Arduino RGB LED Cube (3x3x3)
Intro: Simple Arduino RGB LED Cube (3x3x3)
I´ve been looking into LED Cubes and noticed that most of them were either to complicated or to expensive. After looking at a lot of different cubes, I finally decided that my LED Cube should be:
- easy and simple to build
- affordable
- very stylish and extravagant
After having build multiple Arduino LED Cubes, I can happily say that I created a really cool looking extraordinary Cube that fits my goals.
Now in this Instructable, I´m going to show you how to build your own RGB LED Cube.
Time required:
about a Weekend
Cost:
20-50$ depending on where you buy from.
STEP 1: Equipment and Materials
Tools:
- Soldering Iron
- Cutting Pliers (for cutting the wire)
- Needle Nose Pliers (to bend the LEDs and the wire)
- 3D-printer (OPTIONAL)
- Helping Hands (not necessary but definitely advisable)
Parts:
- 27 x ws2812b LEDs
- 1 x 150 Ohm Resistor
- 1 x Arduino Nano
- a roll of silver plated copper wire
- ~2$ in your local craft store
- Glue
prototyping pcb board / sheet of plastic
The total cost of this 3x3x3 cube is about 18 $ if you buy everything from Aliexpress.
Software:
- Arduino IDE (free)
- CUDA (or your own Slicer for your 3D Printer)
STEP 2: Preparing to Solder
First we have to create a template, so it'll be easier to solder the LEDs together. I used a prototyping pcb board for this and marked two holes for the middle pins of the LED, which are for power supply (as seen on the graphic).
When I built a 5x5x5 version of this cube, I used a sheet of plastic for the template, which also worked very well. If you use plastic or wood, you should drill the pair of holes about 2,4 cm (or 0,95 inches) apart.
STEP 3: Bending and Placing the LEDs
Parts required for this step:
- 27 ws2812b 8mm LEDs
- silver plated copper wire
- prototyping pcb board
In this step you have to bend the pins of 18 LEDs as shown in the picture above. The remaining 9 LEDs have to be bend so that the "Flat Side" will be facing the other direction. After that 9 LEDs with the flat side on the same side must be placed on the breadboard / sheet of plastic.
Additionally, 18 pieces of wire have to be cut. They have to be about 2 cm longer than your LEDs are high. For me, this turned out to be about 6cm (or 2,4 inches).
STEP 4: Soldering the Power
Now you solder the tip of the piece of wire to the top LED as shown in the first picture. Then you solder the wire to the LEDs below. Make sure that no wires are touching each other, or else there'll be a short-circuit; then solder the other wires to the LEDs.
STEP 5: Soldering the Data Pins
This should be easy. You just have to align the data pins from the LEDs and solder them together as shown in the picture.
STEP 6: Removing the LEDs and Cutting the LED Pins
You can remove the LEDs from the template by simply pushing them onto a flat surface as shown in picture one.
After removing the LEDs, you have to cut the remaining ends of the LED pins. After that it should look like in picture 3 and 4.
STEP 7: Soldering the Data Lines of the Layers Together
First you have to place the previously soldered vertical layers in form. While making sure that the distance between the rows is equal, you solder the data pins together as shown in the pictures.
STEP 8: Connecting the Power Wires
Now you bend the ends of the silver plated copper wire as shown in the pictures. It is very important to cross the wires so that GND is connected to GND, and 5V to 5V.
The wires on the outer layers should be bend outwards.
After you have bend all of the wires you go on to soldering them together.
STEP 9: Connecting the Power Wires Part: II
Now it is time to connect the previously soldered power pins. To accomplish this you bend two pieces of wire as shown in the pictures.
Note: Make sure that you have plenty of wire left at the left corner, because this is what we will use to connect to our base.
After having bend the wire into the right shape, you solder them to the pins.
Then solder an additional piece to one of the power wires (the red one in the picture)
Finally, you cut of the rest of the pins as shown in the last picture.
STEP 10: Data Wiring Part I: Bending the LED Pins
In this step you just have to bend all the remaining data pins as shown in the picture.
STEP 11: Data Wiring Part II: Connecting the First to the Second Layer
After you have bend the pins of the ws2812b Leds, you are now going to connect the Data OUT from the first layer to the Data IN of the second one.
To accomplish that you have to bend a piece of wire in to the shape shown in picture 2, which will be used to connect the layers as drawn in the first picture.
The next step is to solder one end of the wire to the Data OUT pin of the first layer. The Data OUT pin is the pin on the flat side of the LED.
The other end is then soldered to the Data IN of the second layer, which is one of the previously bend LED pins on the round side of the LED.
STEP 12: Data Wiring Part III: Connecting the Second to the Third Layer
Next you connect the second to the third layer.
Just like in the step before, you now bend a piece of wire in shape as shown in picture 2. The wire should be bend in this way so it will not obstruct the light of the LEDs and to guarantee an elegant look of the cube.
You then start to solder the short end of the wire to the Data OUT pin of the second layer and the other end to the Data IN LED pin (the one on the round side) .
After having done that, you cut the remaining end of the wire.
STEP 13: Data Wiring Part IV: Soldering the Last LED
To finish the data wiring you now have to bend the Data OUT pin on the flat side of the top layer LED (as shown in the first picture) so that it touches the ground pin.
You then go on to soldering the the pins together and cutting the remaining end off.
STEP 14: Data Wiring V: Completed Result
Now you have finished the building of the LED cube itself. Here are some reference pictures if you had problems understanding the steps before.
STEP 15: 3D-Printing the Base
For this Instructable I have designed a simple, but elegant base, which also serves as the case of the Arduino nano, but if you like, I would appreciate if you share your ideas/ files for another casing. Anyway, you now need access to a 3D-printer. If you don't have one at home, you could go to your local maker space. I have linked the files for you below so you just have to do the following:
- Download the two .stl files from below
- Import them into the slicing software you or your maker space use
- Slice them using the settings below
- Convert to gcode
- Start printing
Slicer settings:
- Layer height: 0.1 mm
- Infill >20%
- Wall line count > 2
- High quality print speed settings (depends on your printer)
You only need to print each part once! After starting a print I suggest to relax, or carry on with the other steps, as the prints take about 2-3 hours combined.
If you don't own or have access to a 3D printer I suggest that you build a simple case, using acrylic or wood for example, as in the picture above.
STEP 16: Connecting Your Cube to the Arduino Nano
- Arduino Nano
- 150 Ohm Resistor
- previously soldered LED cube
- Silver plate copper wire
Now bend the pins of your led cube as in the picture above.
After that you can stick them through the holes of your 3D-printed base.
Then you solder the GND of the LEDs (the pin which goes to the flat side of the LEDs) to GND of the Arduino, and the 5V of the LEDs to VIN.
The Data IN of the first LED should be soldered to the 150 Ohm resistor and the resistor to D4 on the Arduino.
STEP 17: Close the Base
Before you close the base add some glue on the surface.
While closing the base make sure that the USB port of the Arduino is in it's hole.
STEP 18: Program Your Arduino!
You now have finished the building process of your Arduino RGB LED Cube. Now it's time to program it. To do this you should follow these steps:
- Download the Arduino IDE
- Download the FastLED libary
- Import the FastLED libary. Here's a great Instructable for that
- Download one of my examples from below or start programming yourself. I would love to see some of your ideas. (Note: Do not set the Brightness over 40, because then it might be using more ampere than the maximum 200mA the Arduino nano is rated for.)
- Compile & upload the code: Now you can upload your code by simply clicking on the arrow in the top left corner. Make sure that "Arduino Nano" and your correct port are selected in the menu point "Tools".
8 Comments
LateraLiz 4 years ago
Hedel Electronics 4 years ago
czelaitis77387 4 years ago
seamster 5 years ago
Hedel Electronics 5 years ago
