Simple Arduino Robotics Platform!
Intro: Simple Arduino Robotics Platform!
I just got an Arduino after playing around with some AVR microcontrollers during Robotics team meetings. I liked the idea of a really cheap programmable chip that could run just about anything from a simple computer interface so I got an Arduino because it already has a nice board and USB interface. For my first Arduino project, I dug up a Vex Robotics kit I had laying around from some competitions I did in high school. I had always wanted to make a computer driven robotics platform but the Vex microcontroller requires a programming cable that I didn't have. I decided to use my new Arduino (and maybe later a bare AVR chip if I get it working) to drive the platform. Eventually I want to get a netbook and then I can drive the robot using WiFi and view its webcam remotely.
I managed to get a decent serial protocol and a simple example that drives the robot using an Xbox 360 controller connected to a Linux PC.
STEP 1: What It Can Do...
The Arduino is a very versatile platform. My basic goal was just to get the Arduino to interface two Vex motors to the PC, but I had a lot of leftover input/output pins and decided to add some extra stuff. Right now I have an RGB LED for serial port status (green if packets are good, red if they are bad) and a PC fan driven by a transistor. I can also add switches and sensors but I didn't put any of those on it yet.
The best thing about it is that you can add whatever you want to an Arduino robot. It only takes a little bit of interface code to control extra stuff and get input to the computer.
STEP 2: Parts
For my robot, I used a few different parts. Most of the parts were from old stuff I had laying around my basement.
1) Arduino Duemilanove w/ ATMega328
This is the newest Arduino, and since I just got it a few days ago I have the newest one. However, the code is small enough that it should easily fit on any Arduino. It could probably even fit on an ATTiny (if I build a robot controller apart from the Arduino, the ATTiny 2313 looks like a good choice, it's smaller and cheaper but still has plenty of outputs and a serial UART interface)
2) Vex Robotics Platform
I got a Vex kit a few years ago to build a radio-controlled robot to pick up stuff for a high school competition. I constructed the basic "square bot" base that has 4 wheels driven by two motors. You could substitute other robot bases if you have some other platform you want to drive. The important thing to note is that Vex motors are essentially continuous rotation servos, they use pulse-width modulation to signal how fast and in what direction to turn. The Vex motors are nice because they have a high range of operating voltages, somewhere between like 5 to 15 volts. I'm using 12V because I had a 12V battery. For most standard hobby servos, you'll need a lower voltage (often 6 volts).
3) Battery
A robot is useless without a power supply. For testing I use a standard 9V wall-wart adapter from RadioShack, but for cordless operation I found a 12V NiMH battery pack in an ancient laptop. Although it doesn't hold enough of a charge to run the laptop it drives my Vex robot just fine. It can also power the Arduino using the Vin input pin on the power connector, the Arduino will regulate the 12V down to 5 and even output it out the 5V output pin on the power connector.
4) Basic Breadboard
I'm currently using a breadboard to wire everything up. Eventually I'll get a nicer prototyping board and solder on some more permanent connections but for now the breadboard makes it easy to change things. My breadboard is SparkFun's "basic breadboard", just a breadboard on a metal plate with 3 terminals.
5) MAX232-based RS232-TTL converter
If you want to drive your robot using an RS-232 serial port connection (as opposed to the Arduino's built in USB) you can use an RS232-TTL converter. I'm using a MAX232 because I had a few of them lying around and I soldered it on a little piece of prototyping board with the required capacitors. I need RS-232 because my old laptop only has one USB port and I'm using that for a game controller to drive the robot.
6) Extra parts as desired
For easy debugging of the serial protocol, I put an RGB LED on it (got one with my Arduino order cause they sounded cool). The light flashes red, green, blue in sequence when the Arduino boots up to show the robot has rebooted and then lights up Green when a motor packet has been received, Blue when a fan packet has been received, and Red when a bad or unknown packet has been received. To drive the fan I used a standard NPN transistor (the same ones I demonstrated in my last Instructable) and a resistor in between the transistor and the Arduino (the transistor was drawing too much current and heating up the Arduino, so I put a limiting resistor in to stop it).
3) Battery
4) Basic Breadboard
STEP 3: Arduino and PC Programming
To program the Arduino, you'll obviously need the Arduino software and a USB cable. You can also program the Arduino using a serial port and a TTL level converter if your PC has a serial port. Note that the USB serial interface will not communicate with the Arduino's ATMega processor if there is a level converter connected to Arduino's serial pins (pins 0 and 1) so disconnect it before using USB.
On the Arduino we will need a serial interface that allows the PC to control the motors. We will also need a PWM servo drive system to send the correct signals to the Vex motors and make sure they go in the correct directions when given the right values. I also added some simple LED flashing, mainly for status indication but also because it looks cool.
On the PC we will need to open the serial port and send frames of data that the Arduino program will understand. The PC also needs to come up with motor values. An easy way to do this is to use a USB game pad or joystick, I'm using an Xbox 360 controller. Another option is to use a networked computer (either a netbook or a small mini ITX board) on the robot itself to drive wirelessly. With a netbook, you can even use the onboard webcam to stream back a video feed and drive your robot remotely. I used the Linux sockets system to do network programming for my setup. One program (the "joystick server") is run on a separate PC that has a controller plugged into it, and another program (the "client" ) is run on the netbook connected to the Arduino. This links the two computers and sends joystick information to the netbook, which then sends out serial packets to the Arduino that drives the robot.
To connect to the Arduino using a Linux PC (in C++) you must first open the serial port at the correct baud rate and then send the values using a protocol that you have also used on the Arduino's code. My serial format is simple and effective. I use 4 bytes per "frame" to send the two motor speeds (each is a single byte). The first and last bytes are hard-coded values that are used to keep the Arduino from sending the wrong byte to the PWM code and causing the motors to go crazy. This is the primary purpose of the RGB LED, it flashes red when the serial frame was incomplete. The 4 bytes are as follows:
255 (hard coded "start" byte), , , 200 (hard coded "end" byte)
To ensure reliable reception of the data, make sure you put enough delay between program loops. If you run your PC code too fast, it will flood the port and the Arduino may start dropping or even mis-reading bytes. Even if it doesn't drop information it can also overflow the Arduino's serial port buffer.
For the Vex motors, I used the Arduino Servo library. Since Vex motors are just continuous rotation motors, they use the exact same signaling that servos use. However, instead of 90 degrees being the center point, it is the stop point where the motor does not spin. Lowering the "angle" causes the motor to start spinning in one direction, while raising the angle makes it spin in the other direction. The farther away from the center point you are, the faster the motor will spin. While it is not going to break anything if you send values greater than 180 degrees to the motors, I would advise limiting the values from 0 to 180 degrees (which in this case are speed increments). Because I wanted more control and less out of control robot driving, I added a software "speed limit" to my program that doesn't allow the speed to increase above 30 "degrees" in either direction (range is 90 +/- 30). I plan on adding a serial port command that changes the speed limit, so that the computer can remove the limit on the fly if you want to go fast (I've been testing in small rooms so I don't want it to speed up and crash into the wall, especially with a netbook on it).
For more information, download the attached code at the end of this Instructable.
STEP 4: Add a Netbook to Explore Unknown Worlds From a Distance
With a full PC onboard your Arduino robot, you are able to drive your robot from as far as your WiFi can reach without any cords to limit the robot to one area. A good candidate for this job is a netbook, because netbooks are tiny, lightweight, have a built-in battery, have WiFi, and most even have built in webcams that can be used to stream the robot's view back to a safe place where you can control it. Also, if your netbook is equipped with mobile broadband service, your range is practically unlimited. With enough batteries you could drive your robot to the local pizza place and place an order over the webcam (not recommended, robots aren't usually allowed in pizza places, even if they were people are likely going to try to steal the robot and maybe even the pizza). It may also be a good way to explore the dark depths of your basement from the comfort of your office chair, though adding some headlights may be very helpful in this case.
There are many ways to get this working, many are probably a lot easier than mine, though I am not familiar with Processing or script-based languages so I opted to use Linux and C++ to create a wireless control link between my base station (a.k.a. old ThinkPad) and my new Lenovo IdeaPad netbook that is connected to the Arduino drive base. Both PC's are running Ubuntu. My ThinkPad is plugged into my school's LAN and my IdeaPad is connected to my WiFi access point that is also connected to the school's LAN (I couldn't get a reliable video stream from the school WiFi since everyone else is using it, so I set up my own router to provide a good connection). A good connection is especially important in my case since I have not implemented any error-checking or timeout. If the network connection suddenly drops, the robot keeps going until it crashes into something or I run and stop it. This is the main factor behind my decision to slow down the drivetrain both by gearing the motors down and implementing a software speed limit.
STEP 5: Get a Video Feed
After your robotic explorer can drive wirelessly, you'll probably want to have a video feed from the netbook so you can tell where your robot is. If you're using Ubuntu (or even if you aren't!) I recommend using VLC Media Player to stream. If you haven't installed it, you're really missing out, so install it using the command "sudo apt-get install vlc", browse for VLC in the Ubuntu Software Center (9.10 only), or download the installer at videolan.org if you're on Windows. You will need VLC running on both PC's. VLC is capable of streaming as well as playing streams on a network. On the netbook (robot PC) first make sure your webcam (either built-in or USB connected) works by clicking Open Capture Device and trying Video for Linux 2 (some older devices may need Video for Linux rather than the new 2 version). You should see the camera's view on the netbook screen. To stream it, select Streaming from the File menu and then pick the Capture Device tab at the top of the window that appears. Remember that Ubuntu (and many other Linux distros) let you hold down Alt to click and drag windows that are too big for your screen (especially useful on older netbooks, though even my IdeaPad has an odd 1024x576 resolution for no apparent reason). To reduce delay, click on "Show More Options" and lower the caching value. The amount that you can lower it sometimes depends on the device, it gets unstable if you lower it too much. At 300ms you may get a slight delay but it isn't too bad.
Next, click Stream to go to the next menu. Click Next, then select and add HTTP as a new destination. Now set up Transcoding to make the stream smaller. I made a custom profile that uses M-JPEG at 60kb/s and 8fps. This is because using an advanced codec like MPEG or Theora will eat up massive CPU time on a netbook's Atom processor and this can lead to your video feed stopping for no apparent reason. MJPEG is a simple codec that is easy to use at low bitrates.
After starting your stream, open up VLC on your other PC, open a network stream, select HTTP, and then type the IP address of your netbook (either local or Internet depending on how you're connecting) followed by ":8080". You need to specify the port for some odd reason, otherwise it gives you errors. If you have a decent connection, you should see your webcam's feed on your other PC, but it will have a slight (about a second) delay. I don't know exactly why this delay occurs, but I can't figure out how to get rid of it. Now open up the control app and start driving your netbook robot. Get a feel for how the delay works when driving so you won't crash into anything. If it works, your netbook robot is finished.
12 Comments
Gelfling6 11 years ago
Gelfling6 9 years ago
Adding a new note.. The protocol used by the RF module, from the RC remote, is a serial PWM stream. Someone found that there is a 'Start' time, followed by 0-255 ms pulses for each of the joystick positions, and either a solid or no signal points for the buttons on the back.. Wish I could find the page, someone posted on how to decode with a Oscilloscope.
techboy411 12 years ago
IBreakHeavyStuff 13 years ago
PS - any chance of putting some code in there that causes the robot to stop when wifi drops out?
Midwestmariner 13 years ago
paradox116 13 years ago
rhymed 13 years ago
CalcProgrammer1 13 years ago
nawook 14 years ago
Could you please re-upload it ? Thanks !
CalcProgrammer1 14 years ago
nawook 14 years ago
