Introduction: Simple Arduino Timer
Need a timer to check how much times you spent on a task ?
Or maybe you want to make a clock without a RTC module ?
I didn't find a code to make one easily so I share mine.
This is also a good test to check if your DFRobot LCD Keypad Shield works correctly and learn how to use it.
- First, we will upload our code
- Then, we will see how to use our timer.
- Aftewards, i'll explain how to use the LCD/Keypad
- Finally, I'll explain how to manage time
As always documentation and code are available in english/french on http://github.com/pigetArduino/lcdclock
Step 1: Make It!
Components
- Arduino Uno : 6€
- DF Robot LCD Keypad shield : 4€
Total : 10€
You should find theses components easily on most E-commerce using these keywords
DF Robot shield is already soldered, you only have to plug it on the Arduino Uno.
Upload
Download the software, libraries and upload the code with Arduino
- Download : http://lcdclock.madnerd.org
- Copy lcdclock and libraries folder into your arduino sketchbook (Documents/Arduino)
- Upload lcdclock.ino
Board : Arduino/Genuino Uno
- The led on the LCD Keypad can be removed, if you find it too bright.
- We didn't make a 3D printed case for this project, but you can find some on thingiverse.com
Step 2: Manual
Here is a manual on how to use the timer.
- LEFT: -1 minute
- RIGHT: +1 minute
- UP: +1 hour
- DOWN -1 hour
- RST: Reset timer
- Select: Turn off/on backlight
You can use this manual as a template for your own projects:
Download: shield-manual.svg
Every illustrations / text in my tutorial are licence as Creative Commons (by) and available with the source code in the folder docs/
Feel free to use it in your own tutorials!
Step 3: Control the LCD/Keypad
All libraries on my projects are included with the source code.
Official DFRobot manual : https://www.dfrobot.com/wiki/index.php/LCD_KeyPad_Shield_For_Arduino_SKU:_DFR0009
LCD
- Setup screen
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
void setup(){
lcd.begin(16, 2);
- Print Text
lcd.print("Hello World")
- Set Cursor Position
lcd.setCursor(column,row)
KeyPad
- Setup
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
//Buttons are all on Analog0
int read_LCD_buttons(){
adc_key_in = analogRead(0);
if (adc_key_in > 1000) return btnNONE;
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this...
} Check keypress void loop(){
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key){ // depending on which button was pushed, we perform an action
case btnRIGHT:{
//Right button action
break;
case btnLEFT:{
//Left button action
break;
case btnUP:{
//Up Button action
break;
case btnDOWN:{
//Down Button action
break;
case btnSELECT:{
//Select Button action
break;
Step 4: Manage Time
To manage the time , we are using timelib
https://github.com/PaulStoffregen/Time
- Setup
//setTime(hr,min,sec,day,mnth,yr); setTime(0,0,0,1,1,2000);
- Get time
void loop(){
now(); //Get current time
Serial.println(hour());
Serial.println(minute());
Serial.println(second());
