Introduction: Simple Awl for Woodworking, Made Using Basic Tools
Make a simple and inexpensive Awl, also known as Bradawl or Scratch awl. This is a tool with a handle and steel spike, commonly used to mark out work and make indentations in wood and other materials to help in the insertion of screw or nails helping to lessen the possibility of splitting the work piece.
It only requires a few basic hand tools, some scrap pieces of hard wood and a 4mm thick Wall Tie. I have included a section for using power tools if you have them available.
To make using hand tools, you will need the following tools and materials:
5cm long scrap of hard wood
Hard Steel Wall Tie
Hand Saw File / Rasp
Hand Drill
4mm Drill Bit
Spokeshave (optional)
Sandpaper
Hacksaw (or bolt cutters)
Vice or work holding device
Glue
Average time to make 15 - 30 minutes depending upon your skill level
To make using power tools, you will need the following tools and materials:
5cm long scrap of wood
Hard Steel Wall Tie
Drill Press
4mm Drill Bit
Lathe
Bench Grinder
Glue
Average time to make 10 - 20 minutes depending upon your skill level
Step 1: Prepare the Steel Spike
Cut the steel wall tie to length with a hacksaw to use as the spike for the awl. The length of the spike is up to you, but it needs to insert into the handle 3cm deep. I make the spike between 8 - 10cm overall. Using a hand file, create a long sharp point on one end.
Step 2: Drill a Hole to Recieve the Spike
The handle will be made from a piece of hard wood 3cm wide and 6cm long. Here I used Oak.
Place the wood in a vice or other form of work holding device and drill a 3cm deep hole down the center with a 4mm drill bit.
Step 3: Shape the Handle
Shape the handle to a comfortable design that feels good in your hand. The handle in these images was experimental and feels very nice. I placed the wood upright on a bench hook, but it could be clamped to the workbench or placed in a vice. I then cut away any waste using a hand saw. It can then be shaped using a spokeshave or a rasp.
Step 4: Finishing the Handle
When you are happy with the shape and feel of the handle, sand it smooth using a piece of sandpaper wrapped around wooden block and then apply a finish. I use Organic Boiled Linseed Oil.
Step 5: Fit the Spike
When the handle is finished, fit the spike using a strong glue. I use 2 part epoxy. Super glue will work also.
Step 6: Making the Awl Using Power Tools
I use scrap hardwood round blanks from previous projects. Here I used Horse Chestnut. 6cm long and 3cm diameter is a good size. Drill a 4mm hole 3cm deep down the center using the drill press.
Step 7: Shape the Handle Using a Lathe
If you have a lathe available, shape the handle to what you think will feel good to your hand.
Step 8: Make and Insert the Spike
Cut the steel wall tie to length with a hacksaw to use as the spike for the awl. The length of the spike is up to you, but it needs to insert into the handle 3cm deep. I make the spike between 8 - 10cm overall. Grind a long sharp point on one end using a bench grinder if available.
Step 9: Example Designs
This is a selection of awl's I have at various places around my workshop. They are cheap to make and are always available without searching to far.
