Introduction: Simple Beaded Bracelet Patterns - How to Make a Crystal Beaded Bracelet With a Toggle Clasp
Look for simple beaded bracelet patterns? So lucky! Here I want to show you how to make a beaded bracelet with a clasp. Don’t leave; a fab crystal beaded bracelet is waiting for you!
Step 1: Materials Needed in Simple Crystal Beaded Bracelet Patterns:
Step 2: Start to Make the Simple Beaded Bracelet Patterns
1st, cut off about 80cm tiger wire, slide a toggle clasp onto the middle of the wire
2nd, slide a crimp bead onto both wires and pinch it with flat nose pliers.
Step 3: Make the Basic Simple Patterns for the Crystal Beaded Bracelet
1st, slide a drop bead onto one wire, slide 4 abacus beads onto the other wire, cross both wires through another abacus beads and tighten wires;
Step 4:
2nd, add a drop bead to one wire, and add 4 abacus beads to the other wire as pictures show, cross both wires through another abacus and tighten wires;
Step 5:
3rd, repeat the basic pattern to make the rest crystal beaded bracelet until get your desired.
Step 6: Finish Simple Beaded Bracelet Patterns With a Toggle Clasp
1st, slide a crimp bead onto both wires, add a toggle clasp, and then pass the wires back to the crimp bead;
2nd, pinch the crimp bead to fix the end, and then cut off the extra wires.
Step 7: Here Is the Final Look of Simple Beaded Bracelet Patterns:
Good job! Now, the simple beaded bracelet patterns are done! Do you like this crystal beaded bracelet? Base on this tutorial on how to make a beaded bracelet with a clasp, you can design such simple and affordable crystal beaded bracelet for yourself. You deserve to have!
