Introduction: Simple Bots: Wobbler
Typically, you learn how to wobble before you learn how to walk. But in the world of bots, anything is possible! That is why a day after showing you how to walk and two after showing you how I roll, I am back to show you how to do a little wobble wobble. That's right! In almost no time, you can be out wobbling around with the best of 'em. All of the parts in this project are simple to find and even less-than-experienced bot builders should be able to make this one pretty easily. And, more experienced bot builders should be able to have some fun modding this one, as the casing leaves a lot of room for experimentation.
Check out my book Homemade Robots for more projects! |
Want to watch me build this project from start to finish? Check out this webinar I led on June 13th 2017 to see me complete the whole build!
Step 1: Go Get Stuff
You will need:
(x2) continuous rotation servo motors with the controller removed**
(x2) self-adhesive oval coat hooks
(x1) 4 x AA battery holder
(x4) AA batteries
(x1) small plastic container
(x4) zip ties
**To learn how to remove a servo controller, visit this page.
(Note that some of the links on this page are affiliate links. This does not change the price of any of the items for sale. However, I earn a small commission if you click on any of those links and buy anything. I reinvest this money into materials and tools for future projects. However, you are obviously free to source the items as you please.)
Step 2: Remove the Horns
Remove the servo horns from the motors.
(The servo horns are the gear-like objects attached to the motor shafts.)
Step 3: Insert
Step 4: Mark
Step 5: Drill
For the smaller mounting holes, an 1/8" drill bit should be suitable. For the motor shaft, I recommend using either a 3/8" or 1/2" drill bit.
Step 6: Mount the Motors
Step 7: Wire It Up
Next, twist together the remaining three wires to form another pair.
You can solder them for a more permanent bond, if you wish.
Step 8: Close It Up
Close the case and reattach the servo horns.
Step 9: Wheels
You should now be left with self-adhesive oval wheels.
Step 10: Attach Wheels
Step 11: Power It Up
Remove the lid, insert batteries, replace the lid and let it go.
Experiment with putting the bot on different sides to observe all of the ways it moves.
Did you find this useful, fun, or entertaining?
Follow @madeineuphoria to see my latest projects.
