Simple Clay Mold
Introduction: Simple Clay Mold
About: In a past life I was a scenic designer, living in New York and building plays and fashion shows. Now, life has slowed down a bit and I'm figuring out how to be a good husband and dad.
This is a very simple and fast mold for casting plaster or epoxy. I'm sure the picture explains it all, but to make things all good and proper, I'll go through it step by step.
NOTE: This isn't my idea, I'm just reposting it, because I think there are many more applications for this technique. The idea comes from Hirst Arts Fantasy Architecture. If you are interested in this project, I suggest you go take a look there at www.hirstarts.com
Step 1: Push in Original
Push the original object you want to cast into the clay and pull it out.
Step 2: Pour
Pour the plaster or epoxy into the mold. I used Durham's Rock Hard.
Step 3: Let It Dry
Let it dry and peel it out. Bam!
This technique isn't super precise, so you might need to do a little clean-up.
Be the First to Share
    • Jewelry Challenge
      Jewelry Challenge
    • One Board Contest
      One Board Contest
    • Raspberry Pi Contest
    12 Comments
    cutting Matt
    cutting Matt
    12 years ago on Introduction
    would the clay mold get distorted as you take out the casting?
    blksheep
    blksheep
    Reply 12 years ago on Introduction
    It does a little. I just try to be very delicate when pulling anything out of the clay. If it deforms too much, I just knead the clay and try again. This really isn't a super-precise way to cast things, but it is fast, easy and cheap, so it does have an upside.
    RobinD64
    RobinD64
    Reply 5 years ago
    Ok I wanted to make a mold out of like plaster of Paris of star wars figures so I need the details. Then I want to make clay figures with the molds. How would I go about doing this. Getting as much detail as I can and not damaging my original figures.
    cutting Matt
    cutting Matt
    good point! its also reusable! for double sided castings could you just cast both sides and glue them together?
    RobinD64
    RobinD64
    5 years ago
    edward32214
    edward32214
    11 years ago on Introduction
    Whenever your making a mold, i think it would be easier to cast from a flat surface for a more accurate copy. For instance containing your clay in an box and smoothing out the top before casting the plaster or epoxy. Also to have a super accurate copy split your clay and box in half, push in you model get a tube of some kind like a straw and push that adjacent to your model close and fill.
    Sunny124613
    Sunny124613
    13 years ago on Introduction
    ok this is cool,ZIm gonna make one but make ice cubes instead!!!
    John Smith
    John Smith
    14 years ago on Introduction
    Good instructable. You can also cast in lead, like in my instructable. (excuse any grammar or spelling mistakes in mine, that was a couple years ago.)
