Introduction: Simple CloudX M633 Digital Stopwatch
In this project, we are going to make a version of a digital clock that can keep a record of hours, minutes and seconds, just like a stopwatch on your mobile phone! We are going to use an LCD to display the time
Step 1: Component Needed
- CloudX M633
- CloudX SoftCard
- LCD Display
- Potentiometer
- Push Button
- Bread Board
- Jumper Wire
- V3 USB cable
- 10k
You can get your component here
Step 2: HARDWARE
Step 1: Fix the LCD display in the bread board and connect to the CloudX M633 Board as per the following
- R/S to pin1
- ENA to pin2
- D4 to pin3
- D5 to pin4
- D6 to pin5
- D7 to pin6
Additionally, wire a 10k pot to +5V and GND, with it's wiper (output) to LCD screens VO pin .
- connect Vss and K to GND
- connect Vdd and A to +5v
- connect R/W to to GND
N.B: A is Anode, K is Cathode
Step 2:
- Fix the first push button(Start and Stop) in the bread board and connect the first leg to 10k and Pin7 of the CloudX Board and the other leg to GND.
- Fix the Second push button(reset) in the breadBoard and connect the first leg to 10k and pin8 of the CloudX Board and the other leg to GND.
Step 3: CODING
Copy this code to your CloudX IDE
<p>#include <CloudX/M633.h><br>#include <CloudX/Lcd.h>
#include <Cloudx/stdlib.h></p><p>#define START_PAUSE 7
#define RESET 8
#define START 1
#define PAUSE 0</p><p>char timer[] = "00:00:00:0";
unsigned char HH, MM, SS, mSS,mscount, RFlag=0;
bit OmSF=0 , S_PFlag=0 ;</p><p>interrupt TimerOmSD(){</p><p> if (INTCONbits.T0IF) {
INTCONbits.T0IF = 0;
TMR0 += 60;
if (mscount++ == 10) {
mscount = 0;
OmSF = 1;
}</p><p>setup(){
//setup here</p><p> pinMode(START_PAUSE , INPUT);
pinMode(RESET , INPUT);
lcdSetting (1,2,3,4,5,6);
lcdCmd(clear);
lcdCmd(cursorOff);
lcdWriteText(1,1, "CLOUDX STOPWATCH");</p><p>loop(){
//Program here</p><p>if( !readPin(START_PAUSE) ) {
if(S_PFlag == START){
delayMs(200);
INTCON = 0b00000000;
OPTION_REG = 0b00000000;
mSS--;
}</p><p> if(S_PFlag == PAUSE && RFlag == 1 ){
delayMs(200);
INTCON = 0b11100000;
OPTION_REG = 0b00000111;
}</p><p> if(S_PFlag == PAUSE && RFlag == 0 ){
delayMs(200);
TMR0 += 60;
mscount=0;
OmSF = 0;
S_PFlag = ~S_PFlag;
RFlag = 1;
}</p><p> if( !readPin(RESET) ){
delayMs(200);
HH = 0;
MM = 0;
SS = 0;
mSS = 0;
mscount=0;
OmSF = 0;
RFlag = 0;
S_PFlag = PAUSE;</p><p> }</p><p> if (OmSF){
OmSF = ~ OmSF;
mSS++;
if(mSS==10) SS ++;
if(SS==60 )MM++;
if(MM==60 )HH++;
}</p><p>
if(HH==100) HH=0;
if(MM==60) MM=0;
if(SS==60) SS=0;
if(mSS==10) mSS=0;
timer[1] = (HH%10) +48; timer[0] = (HH/10) +48;
timer[4] = (MM%10) +48; timer[3] = (MM/10) +48;
timer[7] = (SS%10) +48; timer[6] = (SS/10) +48;
timer[9] = mSS +48;
lcdWriteText(2,2, timer);</p><p> }
}</p>
