Introduction: Simple DIY Bike Rack (1 Hour Build From 2 X 4 Lumber)
I’d to share a simple and quick bike rack design. This project can be completed in under an hour using 2x4 stud lumber and requires only a table saw and miter saw—no special tools needed! With its space-saving design, this rack is both practical and easy to build. Let’s get started!
Step 1: Structure, Design and 3D Model
The rack is made up of angled cross-sections at 45 degrees and two bottom rails. The gap between the cross bars should be slightly wider than the bike tire to allow it to sit securely in a vertical position. The 45-degree angle of the cross bars helps prevent bike handles from interfering with each other, maximizing space efficiency.
Step 2: Cut, Cut, and Assemble
- cut the cross bars
- cut the 2 bottom rails
- test assembly
- cut 45-degree for all the pieces (optional)
- sanding
- Final assembly
And that's it! The whole thing can be done within 1 hour.
I hope this is helpful to you and I'll see you in the next one.
