Introduction: Simple DIY Farmhouse Style Bench
Do you have a space in your home that needs more seating? An entryway? A living room? A porch? I’m guessing that’s probably the case for all of us. Couches, benches and chairs can all be quite expensive. Well, I have a solution for you: A simple, inexpensive, beautiful and fully customizable bench.
This DIY farmhouse style bench took me about an hour to make and it cost me $30. Check out the simple step-by-step instructions below and then if you’re looking for other farmhouse style decor for your home, check out this $5 DIY Blanket Ladder.
Materials:
1 – 2×10 pine board
4 18″ hairpin legs
Stainable Wood Filler
Stain – Your choice of color
Polycrylic Spray
Orbital Sander or Sandpaper
Tack Cloth
Drill
Step 1:
Cut a 2×10 pine board down to 4 feet long. Many stores, such as Home Depot and Lowe’s, will do this for you free of charge. Otherwise you can use a table saw to cut it.
Below you can see how they cut down an 8-foot board into 3 sections for me. It made it really easy to transport too!
Step 2:
Use an orbital sander to sand down the board, making it smooth. This is important so that no one gets a sliver when they sit down on your bench.
Step 3:
Use a tack cloth to remove all dirt and sawdust from the board.
Step 4:
Fill any large holes in the board with stainable wood filler. It’s important to make sure that you purchase STAINABLE wood filler. Use a putty knife to push the wood filler into the holes, overfilling them just slightly. Wait for the wood filler to completely dry.
Step 5:
Sand down the areas where you put wood filler. You want to create a perfectly smooth surface for your bench.
Step 6:
Stain the board. I chose to use Minwax Special Walnut Wood Stain. To stain it, I simply dipped a rag in the stain and spread the stain over the board as evenly as possible. Allow the stain to fully dry.
Step 7:
Attach the hairpin legs to the bench. First mark the holes with a pencil.
Step 8:
Then attach the legs by putting in the screws.
Step 9:
Spray the top and sides of the wood board with polycrylic spray to protect it. I put on 3 coats of spray to ensure adequate protection.
Now you’ll have a gorgeous bench to put anywhere in your home! Plus, it was inexpensive and easy to make so you can feel good about it every time you look at it.
Step 10:
If you try this, I’d love to see it! Share your project with me on Instagram at @the_handcrafted_haven.
Looking for more farmhouse style decor for your home? Check out these other tutorials: $5 DIY Blanket LadderRustic Farmhouse Style Coat Rack
