Introduction: Simple DIY Jig for Clamping Miters
This is a simple DIY jig for clamping miter joints that allows access to both sides of the work piece for easy removal of excess glue. Its a pretty straight forward video and build but if you have any questions please leave them below and Ill be sure to get to the all! Thanks!
If you like this video please click here to subscribe to my channel!
You can check out my website for more great stuff!
Made from 3/4" plywood
1 - 8" x 8"
2 - 4" x 4"
Step 1: Cut the Three Pieces
Out of 3/4" plywood but one pice 8" x 8" and two pieces 4" x 4" on your table saw or miter saw. I made four of these jigs at one time and batching them out was very simple.
Step 2: Assemble the Jig
Using wood glue and 2" finish nails stack the two 4" squares on top of one another and then attach them to the 8" square. They should be flush to one corner and avoid putting nails in the center of the small squares.
Step 3: Drill Hole for Clamps
Using a 2 1/8" forstner bit drill a hole in the center of the 4" square. The whole should be approximately 1 3/4" deep.
Step 4: Cut a Channel for Glue Squeeze Out
Mark and cut out a 3/4" wide channel from the inside corner of the 4" square. This channel does not have to be precise in width or placement and is used to clean off glue squeeze out when assembling miters on the jig.
Step 5: Use the Jig and Assemble Some Miters!
Now you can use the jig to clamp miter joints in place during glue up. Sometimes it takes a little adjustment to get the correct pressure on the joint but this jig works really well! As always thanks for following along!
For more details you can watch the full build video here:
If you want to see more woodworking and DIY videos then please Subscribe to my channel
