Introduction: Simple Guide to Setting Time on a DS3231/DS3107/DS1337 Real Time Clock With Arduino UNO
The DS3231 is a highly accurate, widely used Real Time Clock (RTC), as are its slightly less accurate counterparts, DS3107 and DS1337. Before it can be useful, however, it needs to be set to the correct time. This Instructable is strictly for the purpose of setting the correct time on a Real Time Clock board using an Arduino UNO. There are other very informative guides about RTC boards, but they contain a lot of extra information that you may not want to read through. You won't get a lot of background in this Instructable, but hopefully, if you've come here looking to set your DS3231 to the correct time, you'll find what you need!
Step 1: Parts
You'll need only:
- DS3231 (or DS3107/DS1337) Real Time Clock (EBay is among the cheapest sources)
- An Arduino UNO (you could use another board but it may use different pins for SCL/SDA)
- A coin cell battery (This article claims you need a rechargeable LIR2032 battery, though they often ship with a CR2032 battery)
- 4 x Male to female breadboard cables
Step 2: Connect RTC to Arduino
- Place the coin-cell battery in the RTC. (The positive side faces outward on most RTC boards)
- Connect only the following four sets of pins together using the male to female jumper cables:
VCC -> Arduino 5V
GND -> Arduino GND
SDA -> Arduino A4
SCL -> Arduino A5
Step 3: Download the Arduino Library and Run the SetTime Sketch
- Download and install the DS1307RTC Library from http://www.pjrc.com/teensy/td_libs_DS1307RTC.html. If you don't know how to install an Arduino library, read the instructions here.
- Connect your Arduino to your computer, then open the Arduino IDE, and open the SetTime sketch which you can find under: File->Examples->DS1307RTC->SetTime.
- Be sure your Arduino is connected to the computer and download the sketch to the Arduino
- Open up the Serial Window - make sure the baud rate is set to 9600. If everything goes correctly, you should see a success message as shown in the last image above.
That's it! You're now all set to use the correct time in your future projects.
Time Contest
9 Comments
Tip 2 years ago
One thing I did find, those extra header holes have a purpose! I installed headers and instead of running separate wires from the Arduino to the display and to the RTC, I found the one side will allow input, the other side input/output, so you can run one set of wires from the Arduino to the RTC, come out the other side and run directly to the Display. This makes for a much neater setup and makes her easier to mount into some sort of case. Just for the hell of it, I dug out an older RTC device with the DS1307 chip on board, it worked just as quickly and just as well, I am impressed.
2 years ago
Thank you so much. I built a little clock out of what was once, well a clock. A tiny computer shaped LCD clock that came with a subscription to a magazine many moons ago. I had it up and working in the orgional build using an UNO, and, as a fellow does, I downsized her to a pro mini to free up my favorite UNO, that went well. Had it set with some program or another when I built it, but I have since changed to a new computer and, well new software and the lot. So here came DST (Why don't we just drop that! The farmers are not gaining anything, they work from dawn to dusk no matter what the damn clock says, I know I grew up doing chores on the home place!) and I attempted to change the hour. What followed were hours of cussing, modifying sketches till their authors would never recognize them should they see the results, all for nothing! Damn little clock showed ANYTHING but the right time! In frustration, this morning, I did a google and came upon your setup. Well I had tried everything else, why not? Worked like a CHARM! Thank you a million times. Now my grandsons can look at what Grandpa built and think I am a genus not just an old fart with a screwdriver and soldering iron!
Question 3 years ago
I have uploaded sketch as per ur instructions on uno its run successfully but last message is not appearing..ie success message.. what to do...also while i am using the RTC 3231 for other ...its message that RTC battery discharged even if i just set new 2032 cell into that.. what to do
3 years ago
I noticed your using the DS1307 settime example sketch, is that made to work with the DS3231 as well?
Reply 3 years ago
Not "made for DS3231" but works exactly as indicated with it with the additional header as noted below.
Question 3 years ago on Introduction
I have downloaded the code. But it has not been useful to me for setting the time on my rtc clock. Is asks 'Skip time setting process (Y/N) and then gives very little time for a response. Once I do get a response in, it automatically sets the year to '13' which means 2013 then asks me for a month, when I type '06'/'6' it responds by making the month 48 or 50 sometimes. Is there a way to fix this or should I just try another code to set the time ?
I am using a DS3231 rtc clock on adruino mega.
4 years ago
Thanks for the Time Set answer. The additional lib did the trick.
Question 4 years ago
When I run the RTC st-time sketch I receive this error: 'tmElements_t' does not name a type". I opened the sketch exactly as you described. Any ideas?
Thanks
Kent
Answer 4 years ago
I just did this myself using an Arduino Uno R3, a DS3231 RTC module and the Arduino IDE ver. 1.8.5 on Windows 10. It works.
Make sure you have both the TimeLib.h and Wire.h librarys already installed.
