Introduction: Simple Headphone Super-Bass Mod
About: If its shiny, if it sparks, if it clunks, and if it on fire, I dig it
Sup guys! In this instructables, i will show how you can take you standard headphones (or even higher end ones) and do an easy mod that takes you less than 30 minutes, but will give you a extreme Bass BOOOOOOOOOOOOTS!!
I will be testing on my pair of Skullcandies which the had strap broke, but i still use it.
Material:
Heaphones (optional..... xD just kidding)
Phillips Screw Driver
Flat Head Screw Driver
Step 1: Labotimizing Your Headphones...
Essentially, the process allows your headphone elements (the heaphone "speakers") to vent air to make it give a deeper sound when it's at work.
First, use whatever you need to open up you headphone casings so you get access to the element.
The screws for this pair was under the ear cushions.
Step 2: Removing Paper Cover
If you see in the picture, you notice that the back of the elements have this black tape like substance going around the edges. Under this layer of tape, there are holes which are going to be our air vents soon.
Get a flat head screw driver and just start scraping away at the paper/tape like material. YOu might need to put some strength into it, but remember not to damage the elements.
IMPORTANT!!!  the tape will not be removed from the holes, but do NOT try to remove them quite yet, you dont it to fall into the element cause you cant get it out then.
Step 3: Now We Puncture the Holes...
Get a very small precision screwdriver (preferably flat head) and we will puncture the holes now. DO SO VERY LIGHTLY, because we do not want to damage the element inside. As you open up the holes, attempt to scopp the tape OUTWARDS so you dont get them into the hole.
After that, just blow away all the paper thingy residue and reseal the headphones. YOU ARE DONE AND ENJOY IMPROVED YOUR  OOOMPHA DA OOMPHING!
