Introduction: Simple K'nex Motor Car
A car made of k'nex run by a motor. The motor is from the carnival set, so you would have to figure something else out if you have a different motor. This is JUST how to build the body. You can make the top however you want.
Pieces needed:
connectors:
20 white, 2 orange, 10 dark grey
bars:
2 grey, 1 yellow, 6 blue, 31 green bars
misc:
4 big wheels w/ tires, 1 motor, 10 brown stoppers
+ whatever pieces you need to customize the top.
Pieces needed:
connectors:
bars:
misc:
Step 1: Build the Body
Parts:
20 White Connectors
31 Green Bars
Arrange the white connectors 5X4, all connected by green bars.
20 White Connectors
31 Green Bars
Step 2: The Axels and Wheels
Pieces:
2 grey bars
4 brown stoppers
8 grey connectors
1 motor
Put the motor in the middle, then slide on the two grey connectors on either side. Next put on the wheels and put a grey connector on either end. Then put in the brown stoppers and slide the little nubs on them in to the holes and side of the wheel facing the middle. Do the same thing again without the motor.
2 grey bars
4 brown stoppers
8 grey connectors
1 motor
Step 3: Attach the Axels to the Body
Pieces :
4 Brown Stoppers
4 Blue Bars
1.Attach the blue bars on the body as shown in the picture with the nubs slid in the little hole in the white connector.
2. & 3. Attach the loose grey connectors to the blue bars.
4 Brown Stoppers
4 Blue Bars
Step 4: Motor Holder
Pieces:
2 Brown Stoppers
2 Orange Connectors
1 Yellow Bar
2 Grey Connectors
1. Assemble everthing as shown below.
2. Detatch the grey connectors and slide the blue bars in the large holes in the white connectors by the axel with the motor on it. Then slide the stoppers down and attach the grey connectors on top.
2 Brown Stoppers
2 Orange Connectors
1 Yellow Bar
2 Grey Connectors
Step 5: Customize the Top
Lastly, make the top however you want. It will run as long as nothing stops the motor. Alternativley, replace the tires with chains if you have enough.
