Introduction: Simple Leather Purse
Here are instructions for a simple leather purse. No sewing is required, just some leather cutting (which is easiest if you have access to a laser cutter) and some lacing.
The purse is about 9" x 9" x 3" when finished.
Materials required (all are available at Tandy Leather)
1) leather (I used a large scrap of vegetable tanned leather): $20
2) lacing (I bought a 35 yard roll of lacing, but only about 3 yards were needed for the purse): $35
3) a lacing needle ($5-$10)
4) a razor (for cutting lacing)
5) a laser cutter (if you don't want to cut the leather by hand)
Attached are five files with the specific pattern I used:
1) a .dwg file (autocad file) at full scale (inches)
2) a .dxf file at full scale (inches
3) a 1/4 scale pdf with a few dimensions
4) a 1/4 scale pdf with no dimensions
5) a full scale pdf with no dimensions
I made it at Techshop: http://www.techshop.ws
Step 1: Cut Out Your Pattern
You have a few options:
1) Be a warrior and use a razor or scissors to cut your lines a drill (1/8") or leather punch to make your holes
2) Get with the times and use a laser cutter
Step 2: Thread Your Needle
There are a variety of needles to use with leather lacing. The type I used was a "Perma Lok" 1/8" lacing needle from Tandy Leather. For this type of needle, you:
1) cut the lacing at a taper
2) put the sharp end of the lacing in the hole
3) twist until it feels solid
Step 3: Bend Your Tabs
If you used vegetable tanned leather, as I did, then you can mold your leather using water.
1) take your center piece (the long rectangle with the tabs)
2) wet the tabs with a damp sponge
3) bend the tabs at a 90 degree angle
This will make lacing the center piece onto the faces easier.
Step 4: Start Lacing the Front Piece to the Center Piece
You may have noticed that there are two more holes in the front piece than there are in the center piece. The first and last holes in the front piece do not have corresponding holes in the center piece.
1) start your lace by going through the first hole in the FRONT PIECE ONLY
- needle goes in on the rough side of the leather, comes out on the smooth side of the leather
2) leave about six inches of lacing hanging on the rough side of the leather
3) go through the SECOND HOLE in the FRONT PIECE and the FIRST HOLE in the CENTER PIECE
You are now set to start lacing all the way around.
PS: Don't worry, we'll finish off that hanging end later.
Step 5: Finish Lacing the Front Piece to the Center Piece
1) continue lacing (up through one hole, down through the next)
2) keep your lacing straight. if it gets twisted, just un-twist it before you pull it tight
3) when you reach the end, thread through the last hole in the front piece (with no matching hole in the center piece)
4) leave yourself at least six inches of slack
The slits you cut for the tabs will allow the center piece to conform nicely to the curve of the front piece.
Step 6: Tie Up the Loose Ends
prep) thread a needle onto your six inches plus of extra lace and wet down the top edge of the front piece with a sponge (so it will stay when you fold it)
1) thread the lacing through the first stitch (needle pointing inward)
2) pull tight and crease the top edge of the center piece (which you just got wet)
3) start threading back and forth underneath the other laces
4) make sure to pull the laces tight under the edge of the leather so they are least visible
5) after three or four passes, cut the lacing close
6) you have now tied up the loose end without an unsightly knot
REPEAT this process on the other side of the front piece (tie up both loose ends)
Step 7: Lace on the Flap Slot
Now, before the back is sewed on and in the way, is a good time to lace on the small "flap slot" that will hold the flap to close the purse.
1) thread down the top left hole
2) up the bottom left hole
3) down the bottom right hole
4) up the top right hole
5) thread both loose ends through the bottom loop and pull tight
6) leave 2-3 inches hanging as a decoration
Step 8: Halfway Done
You should now have the front piece laced to the the middle piece and a "flap slot" laced to the front piece.
Step 9: Lace the Back Piece to the Center Piece
The procedure is exactly the same as it was for lacing the front piece to the center piece, with two exceptions:
1) this time the front piece is in the way, so it's a little more cumbersome
2) you don't fold and crease the edge of the back piece when you tie up the loose ends
NOTE: You don't have to have the extra holes in the front and back pieces. If you don't want a folded top, just skip the first and last holes when you make your pattern.
Step 10: Add a Strap
The simplest way to add a strap is to buy a pre-cut leather belt from the same place you got your leather. You can also cut your own, but you'll need a big piece of leather (expensive) to get a long strap.
1) cut the ends of the belt the way you want them (a simple triangle looks nice)
2) cut four holes to match the four holes on each side of your center piece (using your method of choice: I used a 1/8" drill bit)
3) lace the strap on using the same technique you used for the "flap-slot" on the front
Step 11: Admire
Credit for the original design goes to this image that I found when searching for purse patterns. I copied the proportions pretty directly, but had to make up the dimensions to get everything to the size I wanted it.
OPTIONAL EXTRA: since this was a gift for my wife for our third anniversary, I also used the laser cutter to burn the text of my wedding vows on the inside of the flap.
Second Prize in the
Craft Contest
Epilog Challenge V
3 People Made This Project!
- SquishSquash made it!
- TheBroSquad made it!
- SamPB made it!
37 Comments
Question 3 years ago
Buonasera ma le misure indicate sono in pollici?? avrebbe un pdf con le misure ooriginali?' grazie tony
Answer 3 years ago
Yes, measurements are shown in inches. I just attached a full scale pdf as well.
Reply 3 years ago
grazie provero' a farla
5 years ago
Would make a great Possibles Bag for Black powder shooter . Just make it abit larger . Great work .
Reply 5 years ago
Thanks!
6 years ago on Introduction
Do you have the hole spacing measurements
Reply 6 years ago on Introduction
I don't remember them, but measuring the purse it looks like they were about 1/2" apart.
Thank you very much.
8 years ago
Would be great for a possibles bag at rendezvous
Reply 8 years ago
true that.
8 years ago on Introduction
I miss leather tooling! :) It's a very rare craft - great job.
Thanks!
Sooo reminds me of the Tandy leather kids we did as kids. Thanks.
You can cut holes for the lacing by using a punch or you can take a short peice of pipe and a rubber mallet (or hammer) and punch them that way. If you are careful you can use a knife to cut out the main body and strap. People have been doing leather for longer than even the modern knife was invented. I did respect that the author put in how he used a laser cutter. This purse is beautiful..
very well done, congrats on contest win :)
Definitely cool. I KNOW this will last a long time 'cause my wife still has a similar purse I gave her from my hippie days ... Now I will need to make one for my granddaughter.
Wonder if I can mod this into a laptop/messenger/gear bag ...
8 years ago on Step 11
Nice 'Ible, well written and clear. I've never done lacing as I hand or machine sew all my leather. Buying the leather lace for $30 is simpler but you could have bought a square or larger piece of the same veggie leather and get a lace cutter for $10. The lace cutter is a razor blade that is held off from a guide. The space between is the thickness of the lace. It is easy to use to make your own lace. You can also use the lace cutter to cut the belt.
Veggie tan leather needs protection or water will mark it. Stain it if you wish and then throw some Lexol or some other protector on it and your bag will last generations.
Good tips, thanks!
you use laser cutter to cut a sheet of paper in half as well?
8 years ago on Step 3
You will want to wet the entire piece of leather instead of just the tabs to avoid watermarks.
