Simple Metallic Laptop Stand
Intro: Simple Metallic Laptop Stand
Make a quick and simple laptop stand that will keep your laptop cool for under $10. After looking for a laptop stand for my new macbook pro I decided to create one myself out of a metallic document holder I bought for $6. It keeps the computer off the surface, gives excellent air circulation and elevates it to a comfortable typing angle and it even matches my laptop.
STEP 1: Materials You'll Need
Here are the materials you'll need:
1 Metal Mesh Document Holder (I bought mine at Staples for $6, it comes in black or sliver)
1 Roll of Anti-slip shelf liner (bought it at the dollar store)
1 Small block of rubber - This corner piece came in the packaging of my air-conditioner to protect the corners. You can probably find something similar at the hardware or dollar store such as a rubber sandpaper block; just cut the sandpaper sides off.
Glue gun
Double sided tape
Utility blade
Ruler
Glue gun
Double sided tape
Utility blade
Ruler
STEP 2: Cut Out Two Block's of Rubber
Bend the the Metal Mesh Document Holder so that the long sides lie flat, and flip it upside down so that the short edge sits on the desk. The weight of the laptop will hold the long side flat.
Cut the block of rubber into two pieces using a utility blade.
Using a glue gun, glue each piece to the corner of the Metal Document holder (Glue to the bended edge). This will prevent the laptop from slipping when sitting at an angle.
STEP 3: Anti Slip Strips
Cut out three bands of the anti-slip liner (about 1.5 inches wide) using a ruler and utility blade.
Stick some strips of double sided tape to the liners and than stick the liner to the edges of the document holder. This will prevent any scratching to the laptop from the edges and hold the laptop in place, preventing it from slipping.
STEP 4: Enjoy Your New Laptop Stand
Now place your laptop on your stylish new laptop stand and enjoy.
I think the angle is perfect for typing and the mesh of the document holder creates great circulation from every side. The metal makes it really sturdy and best of all it was simple to make, looks great and cost next to nothing.
44 Comments
fibcoa7 8 years ago
Very good, but since we don't all have blocks of rubber, I suggest using two erasers stacked on top of each other on either side to duplicate the effect. They're essentially the same thing and are pretty cheap at your local Staples.
tasnim70 11 years ago
very goooood
chunkyblamm 16 years ago
uche07 12 years ago
chris99 16 years ago
BEAR2247 14 years ago
IF YOU FIND THE DOCUMENT HOLDER TO LONG FOR YOUR DESK APPLICATION AND SPACE AS I DID AND YOU DON'T WANT THE RUBBER STOPS STICKING OUT IN FRONT. YOU CAN CAREFULLY CUT THE FRONT END, AS DESCRIBED, INSTEAD OF BENDING UNDER, ABOUT 3/4" TO 1" LONGER THAN NEEDED AND PLACE 3/4" OF THIS EDGE BETWEEN TWO PIECES OF WOOD IN BENCH VISE. CAREFULLY BEND THE EDGE UP SO THAT THE EDGE TURNS UP IN FRONT OF THE FRONT EDGE OF THE LAPTOP AT A 90 DEGREE ANGLE. YES, I KNOW THAT THIS WILL LEAVE A SHARP EDGE RIGHT WHERE YOUR WRISTS ARE, BUT I DO HAVE A SOLUTION FOR THAT TOO. GO TO THE LOCAL AUTO PARTS STORE AND FOR A FEW DOLLARS YOU CAN BUY A (2) PACK OF PLASTIC CAR DOOR PROTECTORS, IN CHROME OR BLACK, CUT ONE TO THE WIDTH OF THE LAPTOP HOLDER AND GENTLY FORCE IT OVER THE SHARP EDGE, THIS WILL GIVE YOU A CLEAN LOOK AND PROTECT YOUR WRISTS.
NOTE: THIS WAS A GREAT IDEA YOU HAD AND ALSO GIVES YOU AIR CIRCULATION FOR YOU LAPTOP FANS, GOOD JOB AND IDEA.
BEAR2247
The Arbiter 14 years ago
Namlem 14 years ago
gwaposai17 14 years ago
Kasm279 14 years ago
jdtwelve12 14 years ago
rvdawe 14 years ago
Azn Zero 15 years ago
Harmodius 15 years ago
Chrisxc924 15 years ago
corvett 15 years ago
wezdog1 15 years ago
ghostmanonthird 15 years ago
pear-i 15 years ago
actswaddell 15 years ago
