Introduction: Simple Mobile Phone Stand
I saw online instructions for making a "simple" mobile phone holder, but thought it looked way over engineered and complicated.
It also had 6 or 7 separate pieces.
So I decided to design and make my own, that only uses 2 pieces of wood
This could be the perfect simple piece to make with your kids to give to a grandparent, teacher or friend and provide a bit of "over tool" bonding with your kids
This holder allows your phone to prop up while you are using it for jobs like cooking etc, it also allows the charging cable to be used whilst you are using the phone.
It was made from a piece of scrap Jarrah flooring 18mm thick, I have a load of these small pieces which were offcuts from a neighbours flooring that he gave me.
Piece of wood (mine is Jarrah, a hardwood like teak)
Panel pins or Brad nails
Wood glue
Tools used (because I have them, hand tools can be used)
Tablesaw
Bandsaw
Hammer
Sander
Step 1: The Wood
It was approx 140mm square (6 inches in American freedom units or the width of a bald eagles tail)
Using the table saw I cut off the tongue and groove from each side and then cut it in half.
This gave me 2 pieces approx 130mm long x 65mm wide (5 x 2. 5 inches)
Step 2: Cutting the Phone Slot
Step 3: Cutting the Charger Cord Slot
I then marked the 2 sides of the slot.
Step 4: Cutting the Charger Cord Slot Continued
Step 5: Glueing Up and Nailing
I forgot to take a picture of it so have attached a later one to show the position
Step 6: Sanding
Step 7: Test Fit of Charging Cable
Step 8: Feet
I had these little plastic bits, spare from some "unbranded knock off" meccano.
So drilled 3 holes (7mm) and push fitted them in
Step 9: Finishing
Once it had soaked in I inserted the phone which connected onto the charger cable.
The whole thing sits flat as the cable sits in the slot and the cable take about 2 seconds to disengage from the holder if wanted.
