Introduction: Simple POV W/Ardweeny - Persistence of Vision
About: Retired Math teacher who needs a hobby! So I tinker with stuff: Arduino, welding, my 1958 TR-3 , my tennis serve
This is basically a remake of a previous POV project but I scaled it down a bit
The original is from this instructable https://www.instructables.com/id/Arduino-LEDs-fan-POV-APPLAUSE-sign/
This particular one will be given to a relative who has decided she is a Honey Badger .  Her inspiration is from a popular YouTube video about Honey Badgers.  But the phrase that is produced is easily changed in the code so this is a project that others could use for other reasons.
Step 1: Supplies
Items used in this project:
At a flea market , I had purchased 5 computer fans for a dollar each so I used one for this project.  I was not sure if it would be strong enough to turn with the battery and the attached PCB  but it does turn easily.
misc lumber - my basement - 0.00
a length of plastic  9 by 1.25  inches  - my basement - 0.00
an Arduino - I use a Ardweeny from SolarBotics - about 10.00
7 red LEDs -  already had -  1.00
7 - 470  ohm resistors - 3.00
 1 - 7805 voltage regulator - 1.00
1 - 12 volt wall wart - already had - 0.00
2 - small SPST switches - had  in my supplies - 0.00
1 - old record -  0.00
also will need : wire, 9v battery , screws, Loctite 5 min epoxy, small PCB from Radio Shack
Step 2: Begin Assembly
1. Cut a small - 2 by 2  - piece of 1/4 inch plywood and epoxied to the fan hub . Right now the epoxy is the only thing holding the LED assembly to the fan.  I have had good luck with the Loctite but it could be the weak link in this setup.  Time will tell.
2.  I cut a 9 by 1.25 inch piece of plastic from some stock I had.  Sheets of plastic can be had at Home Depot.  I just  guessed at the size and it turned out to be pretty good.
3. Drill 7 holes in one end about 3/8  of an inch apart for the LEDs.  I found a drill size that allows the LEDs to be pressed into the holes quite tightly.
4. Insert the 7 LEDs into the holes.
Step 3: Wiring the Leds and Attaching to the Ardweeny
The Ardweeny from Solarbotics comes in a kit and it requires about 30 minutes to solder the pieces together. It is intended to be used on a breadboard. After I  have bread boarded the circuit, I solder it to a small piece of PCB board which I can in turn attach to the plywood .  The Ardweeny will spin along with the LEDs.
After the Ardweeny is constructed, it is time to wire up the LEDs.  I used a bare copper wire as a common ground wire.  Each of the short wires from the LEDs is soldered to the copper wire and then the copper wire is connected to a ground on the Ardweeny. From the longer, positive leg, of the LED attach a wire to the Ardweeny and include a 470 ohm resistor in the circuit.
I connected the LEDs to pins 1,2,3,4,5,6,7 with the inner most LED being connected to pin 1.
A voltage regulator is also needed  and I added a small SPST switch so I can control the power to the Ardweeny.
I find using the short lengths of wire with female/male ends already  attached in combination with some headers soldered to the PCB will make the build easier and reuse for possible without a lot of desoldering.
After all connections are made, attach the Ardweeny to the plastic with  small bolts thru a short length of plastic tubing, which is used as a stand off for the PCB.
Step 4: Hall Sensor
This time , I did not use a sensor to trigger the LEDs.  I was able to get it pretty good in the code.
Step 5: Finish the Construction
The remaining steps were:
- attach the plastic arm to the wood hub with small wood screws.
- attach the 9 volt battery to the plastic arm .  As the battery may need to be replaced, I wire tied it to the arm but that turned out to be not enough of a tie down.  As the arm spins , the battery will try to be flung from the arm so I glued in a small piece of wood to keep it from dislodging.  Also the more balanced you can get the arm, the less vibration it will do .
- I then built a stand from scrap wood, painted it black
- I attached the fan (which has the arm attached ) to an old LP record .   The record inturn is attached to the stand .
- I used a wire tie to make a tension relief for the wire and added a SPST switch so I can turn the power on/off to the fan.
- The AC adapter is a 12volt 200 milli amp that I had around.
Step 6: The Code
/ Code for the Arduino Bike POV project
The original code is from an internet find which is noted in the comments
I have modified it greatly
Some issues:
without a hall sensor, one will have to play with the time between words to get a reasonably stable image
// Arduino Bike POV
// by Scott Mitchell
// www.openobject.org
// Open Source Urbanism
// Copyright (C) 2008 Scott Mitchell 12-10-2008
// This program is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// 6/2011 heavily modified by c. Dubois for my POV project
// Hall sensor is a switch so I  used different code for it
// also used a font.h that I found
// defining the alphabet
#include "font.h"
// define the Arduino LED pins in use
const int LEDpins[] = {
   1,2,3,4,5,6,7};
// number of LEDs
  const int charHeight = sizeof(LEDpins);
  const int charWidth = 5;
int var = 0;
int worddelay = 50000;
// sensor setup
const int sensorPIN = 0;  // define the Arduino sensor pin
//  boolean sensorFlag = false;  // stores sensor state
  int sensVal;  // variable to store the value coming from the sensor
const char textString[] = "CLAIRE";
const char textString2[] =" is a ";
const char textString3[] ="HONEY ";
const char textString4[] ="BADGER";
void setup()
   pinMode(13, OUTPUT);
    pinMode(1 , OUTPUT);
   pinMode(2, OUTPUT);
    pinMode(3, OUTPUT);
     pinMode(4, OUTPUT);
    pinMode(5, OUTPUT);
    pinMode(6, OUTPUT);
    pinMode(7, OUTPUT);
  //   Serial.begin(9600);
void loop()
   // turn on Led for a circle in middle and proof that arduino is powered
    digitalWrite(13, HIGH);   // set the LED on
// sensVal = analogRead(sensorPIN);  // read the Hall Effect Sensor
//    Serial.println(sensVal);
// delay(500 );
//  if (sensVal  != 1023  ) {
   //   Turn on the leds to test that they work and create circles
digitalWrite(1 , HIGH);   // set the LED  on
delay(500);
digitalWrite(2 , HIGH);   // set the LED on
delay(500);
digitalWrite(3 , HIGH);   // set the LED on
delay(500);
digitalWrite(4 , HIGH);   // set the LED on
delay(500);
digitalWrite(5 ,HIGH);   // set the LED on
delay(500);
digitalWrite(6 ,HIGH);   // set the LED on
delay(500);
digitalWrite(7 ,HIGH);   // set the LED on
// delay to let the fan get to speed
     delay (3000);
   // printing every letter of the textString
   // then clear and print textstring2
   var = 0;
while(var < 200){
  // do something repetitive 150 times
   for (int k=0; k<sizeof(textString); k++){
     printLetter(textString[k]);
var++;
  // space between words
   delayMicroseconds(worddelay);
        //clear the LEDs
digitalWrite(1 , LOW);   // set the LED off
digitalWrite(2 , LOW);   // set the LED off
digitalWrite(3 , LOW);   // set the LED off
digitalWrite(4 , LOW);   // set the LED off
digitalWrite(5 ,LOW);   // set the LED off
digitalWrite(6 , LOW);   // set the LED off
digitalWrite(7 , LOW);   // set the LED off
// delay between phrases
     delay (500);
// -- now do second phrase    ----
     var = 0;
     while(var < 100){
  // do something repetitive 75 times
      for (int k=0; k<sizeof(textString2); k++){
     printLetter(textString2[k]);
             var++;
       //clear the LEDs
     delay (500);
// -- now do third  phrase    ----
     var = 0;
     while(var < 100){
  // do something repetitive 200 times
      for (int k=0; k<sizeof(textString3); k++){
     printLetter(textString3[k]);
             var++;
    //clear the LEDs
     delay (250);
// -- now do fourth   phrase    ----
     var = 0;
     while(var < 175){
      for (int k=0; k<sizeof(textString4); k++){
     printLetter(textString4[k]);
             var++;
//  -------------------  Functions _________________
void printLetter(char ch)
   // make sure the character is within the alphabet bounds (defined by the font.h file)
   // if it's not, make it a blank character
   if (ch < 32 || ch > 126){
     ch = 32;
   // subtract the space character (converts the ASCII number to the font index number)
   ch -= 32;
   // step through each byte of the character array
   for (int i=0; i<charWidth; i++) {
     byte b = font[ch][i];
     // bit shift through the byte and output it to the pin
     for (int j=0; j<charHeight; j++) {
       digitalWrite(LEDpins[j], !!(b & (1 << j)));
     // space between columns
delayMicroseconds(425);
   //clear the LEDs
digitalWrite(1 , LOW);   // set the LED on
digitalWrite(2 , LOW);   // set the LED on
digitalWrite(3 , LOW);   // set the LED on
digitalWrite(4 , LOW);   // set the LED on
digitalWrite(5 ,LOW);   // set the LED on
digitalWrite(6 , LOW);   // set the LED on
digitalWrite(7 , LOW);   // set the LED on
   // space between letters
   delayMicroseconds(2600);
