Introduction: Simple POV Wheel Lights
This Instructable will show you how to make POV lights for bike wheels that generate random colors and patterns and doesn't require any electronic circuit boards or special skills. When I first saw a monkey light I thought that is cool can I make one? Then I saw the electronics and thought probably not. After a bit more thinking maybe I don't need the electronics just to make random patterns. So I built it, not knowing what i would get in the end but it works pretty good. You don't need much to make them and should only take a couple of hours. Other road user certainly notice you at night and children point and say "look mummy his bikes on fire"
Step 1: Getting Started
Parts List
- 3 LED ribbons (red blue green)
- 3 flashing LEDs
- 2 Nine volt batterys
- 2 Battery snaps
- Cable ties
- Clear plastic or acrylic
- Switch
- Soldering iron
- Hot glue
- Insulation tape
- Wire cutter/ stripper
Step 2: Making the Strips
First thing to do is to make three strips for the LED strips to stick to. I first made a paper template to get the right shape and get an idea of how to attach the strips to the spokes. I decided to use 2mm clear acrylic plastic and simply cable tie it to the spokes. Once the paper template was correct (it took a few tries to get it right) I then cut out 3 triangle shaped strips and drilled hole for the cable ties. You will need to take care when drilling the holes as acrylic tends to grab the drill and split so use light pressure and put the plastic on a block of wood.
Step 3: Wiring It Up
- The red wire from the ribbon need to go to the short lead of the flashing LED and all three ribbons need to be wire like this.
- Next all the flashing LEDs long leads can be wired together with a red wire and all the black leads from the ribbons can be joined together
- The 2 battery snaps can be wire together in series and the then the red and black wires soldered together.
- Once all three ribbons are wired together the red and black wires can be joined to the battery pack and some insulation tape can be used to tidy up the wiring.
- Fit the batteries and you should have a flashing light show.
- A switch can also be fitted if you wish
Step 4: Attaching the Lights to the Wheel
Once everything is working, It just a case of using cable ties to attach the the plastic strips at regular spaces around the wheel, and cable tie the two 9 volt batteries to the center hub. I could could probably come up with a better way to attach the batteries, but the cable ties seem to work quite well. Its also worth the effort to put a switch in the circuit at the battery snaps are difficult to remove one the batteries are fitted to the wheel.
Ive also tried to take a video of the wheel in action but haven't had much success, Its a bit like filming a spinning propeller I keep getting some strange looking results that don't look like anything that you can see with the naked eye, and dont do the project justice. The finished lights It looks a lot like the photos anyway.
Its very hard to even take photographs of the bike in motion with low light so Ive include a few failed attempts before I just gave up and "faked it" Pretend to ride the bike and Ill spin the wheel photos
I Could Make That Contest
Make It Glow Contest
35 Comments
5 years ago
I've thought of trying something like this on my motorcycle, but I'm nervous to throw the wheels out of balance.
6 years ago
looks a bit complicated. http://www.geekled.com/led-wheel-lights
8 years ago on Introduction
thats too much wires ma dude
It would be cool if this was pedal powered. :)
Wouldn't this circuit more accurately be described as Series/ Parallel since part of it is in series and part of it is in parallel?
Nicely done. Since I am a cycling commuter, I shall build this, especially with these shorter days and I'm often riding 13 miles in the dark. Have the front and rear lights already, but this will be cool.
Thanks!
thanks homee
Great start man ! You know, if you make a plan of a snap-on housing for the batteries, and simplify the contacts (like maybe a rotating "switch" that goes on and off as the wheel and its lights go around and contact is "intermittent", eliminating the need for a flasher.) Then of course you have the light generators that were popular (and much more effective) before these goofy flashing lights came on the market, I mean like doing 60 miles an hour down a dark mountain road surrounded by trees, so you don't even get moonlight nor light from neighborhoods a half mile away, right? So you need a constant source of light on a bicycle or motorcycle, or you're gonna hit something you didn't see because of the shadow patterns from the Flasher! Anyway, got on a tangent there! ha,ha! (The reason I mention that stuff is that I lost my lights in a similar way, because I was going so fast down a windy hillside, it burned out my generator! Fortunately the guy behind me (a pickup truck) had his lights on, and I used those to make it down! When he passed me at the bottom, he hollered out the window that I was really going fast, hollered back that I'd just bought it and was testing it out! We laffed and went on! Oh well, just another moment in our own little twilight zones! Good thinking Man! Have fun! Happy Halloweeeen ! ha,ha! (Oh, by the way, that rotating switch wouldn't be cheap, but you could sell a Kit (Shark Tank Moment?) and it would sell ! Free Country ! Good Luck !
I learned a trick back in my electronic assembly days with hot glue that a compressed air can is your friend. If you turn the can up-side-down when you spray, freezing cold air comes out and can instantly cure your hot glue. This also has the nice advantage of keeping your glue clear and cloud-less. Plus the added advantage of setting quickly.
thanks thats good to know
8 years ago
There from Argos
Maybe setting the leds in clear plastic tubing and fastening it to the spokes will make for a cleaner setup and will give better light for both sides... I see Burning Man builds with these setups coming up!!!
Thanks I hadn't thought about putting the ribbons in tube
Nice project. Was looking for information for a DIY IR flood light recently and this guy had a circuit you might find useful. http://homemadecircuitsandschematics.blogspot.com/2011/12/infra-red-ir-led-flood-light-circuit.html.
Thanks
I wonder whether you could rig something up with capacitors so the pedaling of the bike would be the power supply and the capacitors would let it out at the right voltage/current? (I can't but I thought someone here might know how.) No batteries to replace then.
Magnet on the forks and a Coil on the spokes would do that, certainly enough to be able to run one of the smaller systems, not sure about this one since it needs 9v.
Awesome!
Thanks Audrey, I was going for fabulous, but awesome is even better.
double awesome!
