Simple PUBG K'nex Kriss Vector
Intro: Simple PUBG K'nex Kriss Vector
Hello! Glad you are checking out my first instructable! I present to you: My (simple) Knex Kriss Vector! i don't really have to much to say, because seriously, it speaks for itself if you build it! Here are Some stats:
Accuracy: from about 6 1/2 feet it has about a half foot diameter of where it could hit. So, 7/10
Stability: old version (not this one) 4/10, current version 8/10
Comfort: old 4/10, grip could be modified, current 8/10
Power: for its size it is a 10/10 in my opinion. I have never built anything so powerful.
Range: 60 feet on a fairly calm day.
Shout outs: dsman195276, for his crossbow trigger system, and Lucas the boss, for the idea of the vector and general design.
STEP 1: Trigger Chunk
Follow Pics
(each number is a picture)
1: Make
2: make
3: connect
4: make these
5: connect like that
6: do same on this side
7: make these
8: get this
9: snap on like so
10: make trigger, then slide it on (take note of which way it is facing!)
11: snap on like so
12: connect
13, and 14: make sure that the black (or white) rod is like this, and can reach the spindle/white connector!!!
STEP 2: Barrel
This is a bit tricky, but I believe in you!
1: Make
2, 3, 4, 5, 6: different angles of 1
7: connect to step one: connect and twist, and then pop in the other 2 on top (pic 8)
9: 8 should now look like this
10: the whole gun so far should now look like this
11: get this
12: hook on the trigger like so
13: hook on the barrel like so
14: elastic should now look like this.
15: Gun so far
STEP 3: Stock, Grip, and Shoulder Rest
should be easy enough
1: make
2: make
3: connect
4: make
5: make
6: connect
7: place
8: same on this side
9: place
10: same on this side
11: gun so far
12: make
13: get
14: connect
15: connect
16: make
17: connect
18: get
19: connect
20: gun so far
21: shoulder rest is tricky: make this
22: connect
23: gun so far
24: make
25: connect
26: gun so far
27: make
28: make
29: make
30: connect
31: connect
32: connect
33: what gun should look like so far
STEP 4: Body, Fore-grip, Ammo, and Firing
Should be easy...
1: make these
2: connect
3: same on this side
4: make
5: make these
6: connect
7: connect
8, 9: NOTE: ELASTIC MUST BE LIKE THIS OR THE TRIGGER WILL NOT WORK CORRECTLY!!!
10: make
11: connect
12: make
13: get
14: slide in like so
15: snap on
16: make
17: connect
18: connect (may be tricky)
19: it is done!
20: get these
21: put them like this
22: when loaded, elastics must look like this and put the elastics on the spindle like this(23, 24)
25, 26: hold like this
27: ammo
28: set ammo in like this
29: shoulder rest position
30: Should look like this when it is done!
