Introduction: Simple Removable Car Sun Shade
A simple and easy way to protect yourself and your children from the sun heat in long trips
Step 1: Prepare the Window Shapes
take an A3 papers and push them towards your car windows to have the shape of them
Step 2: Cutting
cut them in the shape of the car windows
Step 3: Double Them
now take more papers and draw the templates on them .. this is to make your sun shade thicker
add papers as more as you need but be careful more paper can lead your lamination film to torn. I used only two papers with one picture cut inside
Cut them all in same shapes.
Step 4: Stick Them to Gether
stack them together then put them in a laminating film . with the help of heat they become hard which now we can use by the way that we need
Step 5: Re-cut
now re-cut the not needed edges into the same shape of the template.
be careful, you have to leave at least about 1cm from each side of the paper to not lose the laminating film and to make the area which will go between your car window and its rubber frame.
I add some pictures of prayers and habits that i want my son to read and follow .. you can add any pictures or any thing that you thing it will add a decorative appearance to the sun shade.
Step 6: Use Them
now easily slide them between your windows glass and the rubber frame.. the 1cm area of the lamination film will go inside leaving the paper as its glued to the window. by this there is no more sun rays coming inside.
there is a small mistake that I've done.. those papers are for the right side of the car but because there was no space in parking area i put them in the left side only to show you the how it is. (Also one paper is mistakenly flipped)
if you didn't add any picture you can use your papers in either side of your car.
Step 7: You Can
you can use any laminated A3 of A4 paper and slide it into the windows to protect you from sun if you don't want to make it hard for you.
