Introduction: Simple Working Silencer for Airsoft Guns
It is a very simple silencer but it dramatically muffles the sound of the Airsoft gun.
Step 1: How to Do
It is simple. Take a cardboard and roll it to make a cylinder, Punch small holes on it. 3 holes are enough. Make sure the holes are disperse and facing different directions. You can get the best results with a 120 degree angle between the holes. This avoids sonic resonance and spiralls the air through the silencer. Also seal the top of the cylinder with paper, than let the BB bullet to penetrate the paper. Then use some tape to harden the area around the hole.
The principle is simple, we are forcing the high pressure air to be released slowly. This is also the principle behind the real silencers.
I tried it and it works pretty well. It suppresses the sound seriously but also it makes the muzzle noise much more bass.
(note-1: this design may be much better if made up with plastic)
(note-2: most of the silencers for airsoft guns are just cylinders without holes, so it just tunnels the air and makes the sounds more bass, but doesn't muffles the sound at all. This one uses the principle for real silencer so it actually works very good even it is a very simple design)
(note-3: diameter of the holes should be 3 or 4 mm)
