Introduction: Simple Skateboard
This is what a skateboard looks like.
Step 1: The Board
The
board is 110cm long, 25cm wide and 8mm high.
Step 2: The Board Head
The
board head is 20cm long, with an included angle of 30 ° with the horizontal, and is the same board with the board body.
Step 3: Wheel
Wheel
diameter 6cm, bearing diameter 3cm
Step 4: Wheel Spacing
The
distance between wheels is 18cm, and the wheel shaft is fixed by two rings.
The material has strong toughness and high hardness.
Step 5: Fixing Screw
Fixed
device under the bearing rod
Five screw fixing devices,
Step 6: Auxiliary Plate
The
height of the auxiliary plate is 5mm, which can increase the distance between the wheel and the body.
As well as the roof body and wheels
