Introduction: Simple Skateboard Rack
This simple skateboard rack can be easily customized for up to five skateboards and can be built with a single 8' x 2" x 4" piece of lumber. If you're able to find a nice, surfaced piece of wood you should only need a miter saw or even a handsaw and a drill to build this. I'll be using a piece of cedar from a local reclaimed lumber store that unfortunately needed a little cleaning up.
Step 1: Preparing the Lumber
This piece of cedar was fairly rough and had some damage to it that needed cutting out. I started cleaning it up by running it through the jointer and planer. After that I ripped the worst of the damage off at the table saw. The final width was roughly 3.5" wide and a little over 1.75" thick.
Step 2: Cut the Pieces
With the board cleaned up, I started by cutting the back piece to length. I then cut all the 45° angles for the smaller front pieces. Here you could definitely make adjustments depending on how many boards you wish to display.
Step 3: Trim the Top Edges
Once all the pieces were cut, I trimmed a little off the top lip of each to help prevent them from chipping when skateboards were placed on the rack.
Step 4: Glue the Pieces
Next I marked a few guidelines for positioning the front pieces with roughly a 3/4" gap between each piece. I then glued each of the front pieces onto the back using Titebond Wood Glue. Setting up the clamps was a little annoying as the pieces wanted to squirm around a bit, but it turned out fine in the end.
Step 5: Clean the Glue Joints
Once the glue had completely dried, I used a card scraper and some sandpaper to clean the glue joints.
Step 6: Drill Mounting Holes
Next, I drilled a counter-bore hole in the top and bottom of the rack for two 4.5" Heavy Duty HeadLok screws. I drilled these so that roughly 2.5" of the screw would extend out the rack for mounting to the wall.
Step 7: Apply the Finish
For the finish, I used a coat of boiled linseed oil followed by several (6-7) thin coats of homemade wipe-on-polyurethane (a 1:1 ratio of Clear Gloss Minwax Polyurethane and Mineral Spirits). I sanded lightly between roughly every other coat.
Step 8: Attach Screws for Hanging Helmets
Finally, I predrilled and added two cabinet screws (the HeadLok screws would also work) to the bottom of the rack for hanging helmets.
Step 9: Mount the Rack
To mount the rack I located a stud and predrilled a hole for the top screw. I then hung the rack with only the top screw with it just barely loose (so that it could still be rotated). After leveling the rack on the wall, I marked where the lower screw should go and rotated the rack out of the way in order to predrill the hole. Finally, I added the lower screw and tightened the top screw.
Step 10: Hang Your Gear
That was pretty much it! This rack was for a friend of mine, and while it was pretty simple to build, I spent a little extra time on the finish which I think turned out pretty nice.
If you have any questions, please leave them below and check out the free plans if you're interested in building one yourself.
Step 11: Parts List
- 8′ x 2″ x 4″ Cedar
- 2 - 4.5″ Heavy Duty HeadLok Screws
- 2- Cabinet Screws (or 2 - 4.5″ HeadLok Screws)
- Wood Glue
Step 12: Tools Used
- Magswitch Magnetic Feather Board
- Power Hands Push Stick
- Card Scraper
- 10″ Dewalt Compound MiterSaw
- Grizzly G0691 Table Saw
- Grizzly G0586 Jointer
- Ridgid R4330 13″ Planer
- Craftsman 17″ Drill Press
Step 13: Plans
Free PDF and SketchUp Plans can be downloaded from our website.
