Introduction: Simple Storage Box
I made this simple storage box for my baby's toys. It's an easy one day project and you can improve or add your own design to it.
Material you will need:
Safety : When using electric tools use ears and eye protection.
Keep body parts away from sharp blades. WORK SAFE!
- Your choice of wood.
- Mitre saw, skill saw or hand saw.
- Jigsaw (use special blade for cutting angles)
- Biscuit jointer and biscuits no10.
- Hand sander. different grit levels.
- Cordless drill ( for screws and pilot holes)
PVA Glue, glue roller, tape, pencil, screws, pins, 2 hinges, clamps, set square, ratchet straps or long clamps.
Step 1: Choose Box Material
You can make the box from a few cheap materials such as soft wood, plywood, mdf board and more. After deciding what material you are using think about the pratical size of the box and what will be its purpose. I made my box size Length=800mm x Width=380mm x Height=450 that is a good size for keeping all my baby toys tidy in one box. I chose to use soft wood 19mmx144mm.
- Start by cutting your length and width size using a mitre saw or hand saw.
- Don't forget to subtract the thickness of the material x 2 from your width to achieve your box width design.
- Use a long set square to mark the lines between the joints, those lines will guide you when using your biscuit jointer.
Step 2: Using a Biscuit Jointer
- Choose your biscuits (don't eat them!!! ) I used no 10. Set your jointer height so the blade will be in the center of the timber and set the depth of the blade to be in the center of your biscuit.
- Most important: work on a SUPER FLAT surface or your joints will not match. Hold the jointer using the red guide line against your pencil mark on the timber, turn jointer on and push it into the timber moving about 5mm left and right to create a wider joint in case you miss the mark.
- After all joints are ready make a dry assembly to see if it all fits nicely together.
- Use PVA wood glue, don't be shy make sure you get good glue coverage in all joints, use a glue roller to spread it all evenly.
- Attach all parts to each other and wipe excess glue with damp cloth.
- On a flat surface use clamps to pull parts together, what will happen is the timber will lift up like a banana so use 2 thick lengths of timber and clamp them pushing the work piece downwards.
Step 3: Cut Support Angles
Here I used 2*2 timber cut in the center with my mitre saw to create the support angles for the inner box.
- Screw 2 screws in an angle to support the timber. keep the screws away fromthe path of the blade.
- The support timber is for your own safety, keep your hands AWAY from the blade.
- The corner of the 2*2 should by aligned with saw blade.
- When cutting make a few passes on the 2*2 don't force the blade in one go.
- Cut angle end (for decorative purpose).
- Sand the 4 angles.
Step 4: Box-Lid
Same again using a biscuits to join lid parts. Try adding a few extra biscuits making the joints closer to each other since the lid will be opend and closed many times.
Step 5: Check Box Is Square and Make the Box Base
I ran out of big clamps so I took my emergency ratchet straps and used them to secure the box after gluing all sides.
If you want you can use screws or nails for the sides.
- After securing the ratchet straps check your box is square by mesuring from one diagonal corner to the other.
- When tightening the straps don't forget to place small blocks under the ratchet metal part as they will mark the soft wood when pressed against it .
- Use your mitre saw and cut 20-30mm strips to support the base of the box.
- Glue support strips, small pin-nails or screws are optional.
- Glue box base. I made the base of the box from left overs of my wooden floor.
- After the glue is dry use a small sander and sand all box parts starting from low grit to high grit (fine) .
Step 6: Enjoy Your Storage Box
- Glue the support corners in.
- Attach small hinges.
- Round lid corners with jigsaw.
- Make 2 segments / arcs on the sides of the box for lifting. when using the jigsaw use special blade for cutting angles.
- Attach 2 straps to the inner box lid as support, glue, screw and close with hard wood plugs. You can paint this simple box, add mouldings or use electric router to create a few shapes or writings on the box.
- Be creative my baby sure is.
Step 7: Lid Stay.
I add this step after comments regarding lid stay for child safety.
I am not going to promote products and brand names any one can Google "lid stay" will find many different lid stay devices all over the net.
I attached a few images for safety devices and where to attach it on the box.
Regarding the danger of suffocation it will not happen if you cut vent holes (like the arc for handles on the sides of the box).
4 People Made This Project!
- londobali made it!
- deant_b01 made it!
- Nakedgolfer made it!
- nyromaniac made it!
61 Comments
1 year ago
Hi,
Thank you for the great tutorial! This box is just awesome :) It's simple and feasible, not like many other sofisticated projects out there! I have made one and it looks nice. I am happy with the result! I have also taken advantage of other plans here: http://bit.ly/woodprojectsfans which I found really helpful for my wood projects.
Stay safe!
2 years ago on Step 7
when I click download, it just wants me to verify my email over and over again! are your plans really not free to download?
3 years ago
I used an MDF base, with a few perforated hardboard sheets joined together (to create thickness) for the sides, and had a stained oak ply for the lid. I put a latch on the front so it could be locked, and added a garage door handle to the lid
Question 3 years ago
what sort of timber would others recomend for something like this ?
Answer 3 years ago
When i made this i used an mdf base, with a few layers of perforated hardboard on the sides and stained oak ply for the lid to give a bit of decoration, however as mentioned above, pretty much any soft wood will work, depending on its intended perpous.
Question 4 years ago
How can I get plans for the above project or any other project that Instructables posts online?
6 years ago
I made a toy box like this, but rather than buy the joiner, I just bought T&G flooring that's already designed to combine into a flat plane. A Liquidator store had the bamboo my wife like on clearance, so it was pretty inexpensive. Better yet, they had rough 3x3 pallet strap supports that were being discarded, that they allowed my to salvage.
6 years ago
The pictures are awesome! But of course kids would love playing with the wooden box! Haha! And the box would be great for keeping their things organized. No doubt moving house, including toddlers like this little fellow here, would be very fun with lots of these crates around to imagine things in! Castles and boats and all of that kind of thing. Nicely done!
6 years ago
This storage box would be a great help for getting the storage room sorted out. It can help to store all the things together and prevent a mess from being created. When more than one box is stacked up together on top of one another, more space can be created as well to increase storage.
6 years ago
I am sure you can still buy handbook with all info you need on http://woodprix.com :)
6 years ago
That picture of your kid in the storage box - CLASSIC! Kids love playing in boxes of all sizes!
6 years ago
Which woodworking plans site is best? Anybody have some good
recommendations?
7 years ago on Introduction
7 years ago
I haven't built this yet but it's what I was looking for-for my two sons. thank you for sharing
This storage box looks simply stunning! I love things that are customizable so I can add a coat of my favourite colour that would match my other furnishings around the house. I think this would definitely be perfect for anywhere, be it the living room, bedrooms or even the bathrooms for towels and other accessories. However, having seen your adorable child in it, I think this best suit the children’s room which is inevitably messy with countless toys and knick knacks.
I am going to make this! However, with a few modifications... I want to be able to have a lift out tray to store items I use on a daily basis and I would add wheels to the bottom in order to move it around easily. Also, I could also see using this to hold my notebook PC just by turning it backwards so the lip on the bak would prevent the laptop from sliding off...
8 years ago on Introduction
We have a similar storage box for toys and knick knacks but we did not DIY it. We just bought it off a furniture store and it was made of plastic. We need more of such storage boxes but it was quite pricey when we bought it. I think it is a great idea to start DIY-ing our storage boxes which is more cost effective and they are customizable too.
9 years ago on Step 2
Kreg Pocket Jig is one method (one I actually love as I own one).
Making a 15degree hand router slide block is another way to make a pocket bore slot. Both methods are great for flat jointing panels.
Another method if you have a table saw is tongue and groove. A router is beter suited for this if you have a table mounted router. Both allow you to set your cuts to have a flush surface.
Another method uses a Hand router and a jig that creates a slot in both boards and placing a piece of wood like a biscuit but uses a home made jig that clamps to the boards using the router to create the biscuit slot.
Another method if you have a table saw is using a 4" diameter x 1/16 scoring saw that cuts a 1/16 groove in the edge of the board. Then you can use 1/16 edge shavings from the edge of a board to act as the biscuits but as one long continuious biscuit down the length of the board.
Clamps are still a must for any of these methods.
Last is a $45 + (price will vary where you find them.) is a Table mounted Router with a finger joint router bit from Skill. There are other router bit companies that have more expensive versions but if you have a simple router table and this one bit you can finger joint all your planks together with an extremely strong glue joint.
Unfortunately,I do not have a pro account so I have no way to show you each of these methods. Just saying there are other methods than biscuits and dowels.
Happy Woodworking.
9 years ago on Introduction
Great design. I can't see how suffocation can be an issue given that there are two big holes in the sides. PLUS we never had soft closing mechanisms growing up and we are still here.
I'm off to build one of these tomorrow.
You can get biscuit bits for routers.
10 years ago on Introduction
Love your instructable! Following your easy instructions I used builder grade plywood and I split 2 X 4's to make a box for my firewood. Thanks
