Simple USB Switch
Intro: Simple USB Switch
This is the most simple USBĀ switch I could come up with. It doesn't require IC's or any other complex circuitry.
All it requires is:
One 4pdt switch
Two USB female ports
one USB cable
and a case
All it requires is:
One 4pdt switch
one USB cable
and a case
STEP 1: Prepare the Case
this will differ depending on what you use, I used an old power brick.
Just make a hole for your toggle switch and USB ports
STEP 2: Wire the Switch
Now the switch needs to be wired.
It doesn't really matter what order the wires are in, as long as they line up on the switch.
STEP 3: Test!
Make sure double check the wiring before testing!
It's a good Idea to test this before you put in the case, otherwise you might get all put together, plug in, and it doesn't work
STEP 4: Assembly
Now put your USB switch in it's case and your done
8 Comments
n3pla2000 3 years ago
Atariiatarii 11 years ago
EttoreS1 8 years ago
Yes, it works in reverse. I needed this way too. Its fully functional. =]
pjhenry1216 9 years ago
I would also like to know if this could work in reverse. If anyone has any insight into this, that'd be appreciated. I too would like to have a usb switch that can basically act as a switch between a USB hub and two different machines.
ahussain29 9 years ago
This usb switch solve my problem of plunging unplugging USB cables. I use tenda wifi usb router with USB adapter and power bank. With this switch I can keep my usb adaptor and power bank without unplugging and just switching on power failure. This usb switch will not use any energy so that I can save my battery life. USB switcher/hub available in the market have little circuit which consume power and I do not want to loose my power bank battery.
sctirvn687 11 years ago
T_T_ 11 years ago
right now I don't use it, as I've upgraded my computer and have no shortage of ports, but it is much easier than unplugging the cables, especially if the ports are on the back.
T_T_ 11 years ago
