Introduction: Simple UV Lightbox for PCBs
How to make a simple yet professional looking UV lightbox for PCB production.
With a few items salvaged and picked up in car boot sales you can make an effective PCB exposure box for less than half the price of the cheapest commercial boxes. I have made four of these units (some double sided) yet still use the first one I made nearly ten years ago!
I have decided to update my old battered box with a snazzy new one and thought it would be a good idea to share my experiences.
Step 1: Basic Materials
The basic materials and tools you will need are:
A metal clad tool case (Maplin, B&Q, tool shops - see photos).
Perspex sheet 3mm thick and the size of the inner rim of the lip of your box (see photo later).
M3 Nuts, bolts and washers (20 or so will cover it).
Black card sheet (A3 size, Staples).
2x UV-A tubes - not blacklight tubes, you need to get the right ones (Rapid, CPC, Specialist).
Tube "U" clips to fit the tubes - metal sprung type.
Mains rated switch (Maplin, Rapid, CPC etc...).
Mains flex 3M or so, 3 core 5A (to use whole and stripped into conductors).
Heatshrink tubing slightly larger than the wiring you will use (inner conductors of mains flex).
Ring terminals.
3A Terminal block or "chocstrip"
Mains strain relief cable gland (Maplin, electrical supplier) to fit your mains cable.
Various short screws, pan head and countersunk self tapping.
Sticky tape
2 small blocks of wood 1"x1"
Mirrored card/plastic or tin-foil.
Tools:
Drill.
Drill bits.
Soldering Iron.
Solder.
Crimp tool for ring terminal.
Small flatblade screwdriver
Cross blade screwdriver
Wire cutters.
Long nose pliers.
Pliers.
Knife or scalpel.
Vacuum cleaner.
Ring terminals.
Sticky tape
Tools:
Drill.
Drill bits.
Soldering Iron.
Solder.
Wire cutters.
Long nose pliers.
Pliers.
Knife or scalpel.
Vacuum cleaner.
Step 2: Strip Out the Toolbox!
Strip out the dividers inside the toolbox and save one vertical divider, we need this later.
Step 3: Mount the Ballasts
I salvaged these two ballasts from discarded fittings (ok skip diving!) but they saved me £20.
Each ballast is capable of driving up to 13 watts. We are going to use two 8 watt tubes so we need two ballasts (you may find one which drives both tubes but you will need to modify the wiring to accommodate this).
Leave enough room around your ballasts to get the wiring in. Your ballasts may have different mounting lugs but these had two which were offset in each corner. Mount using your M3 fixings.
Step 4: Mount Your On/Off Switch
Now mount your on/off switch to the front panel. I like to use big chunky toggle switches but you might opt for a nice illuminated type. Mount close to the right hand side of your box.
Drill carefully from outside in, the thin covering of your toolbox tears easily. You may have to cut some of the box lining out to get your switch to mount properly. I found using a nice sharp scalpel helps.
Step 5: Install Mains Cable and Wire Up the Ballasts
Next step is to install your mains cable using the strain relief gromet, wire up the switch and earth your casing. Use heatshrink to cover up the terminals on the back of your switch once you have soldered the wires onto it.
Warning: because your box is metal it needs a good earth, bolting the earth directly to the casing is best but as the box is made from sectional panels so you may have to provide multiple earth bonds. Think safety - I use a 30mA RCD with pretty much everything with exposed metal parts be it double insulated or not.
At this point you can wire up your ballasts too using your spare stripped mains cabling conductors. The ballasts I have feature spring contacts which trap the wire. Wire up as per the wiring diagram with the mains feed to them in parallel. Leave enough wire to reach to your tubes in the main compartment of the box.
Step 6: More Wiring!
The next step is to mount your starter bases with the M3 nuts and bolts and wire the starters up, again leave enough wire to reach your tube ends when we install them.
Install the bases as close to the right hand side of your box as you can so all the working parts are in a neat confined space.
Step 7: Encase the Gubbings!
Next, use one of the vertical dividers saved when you stripped your box out to make a compartment for the working parts. You will need to drill a hole big enough to allow the cabling to pass into the lamp compartment (see photo).
You can glue the divider in but I reccommend just pushing it in so it can be removed for repairs if you need to.
Step 8: Install the Tube Bases and Mirror
The next step is to decide where you want to put your UV tubes. Place your mirrored card/plastic/tin-foil down first and clip the tube holders onto the tubes about 10mm in from each end.
Cut up eight pieces of choc-strip connector and screw them onto the tube pins (unless your posh and have tube connection clips!) this makes wiring to the tubes easy.
Place the tubes down on the mirror and shuffle them around until they are in line and leave enough room at either en of the choc-strip to fasten the wires in.
With a small marker pen, mark where your tube clips are and then drill and bolt the tube holders down into position.
Step 9: Wire Up Your UV Tubes
Now for the last of the wiring! Wire up your tubes as per the diagram. Both of your tubes need a neutral connection so parallel one off with a bit of the choc-strip (top left photo) or parallel from the first tubes connection whichever...
Clip your tubes down into place and give the whole box a good vacuum out as we are about to seal it.
Step 10: The Initial Test!
Right, now we can give it a dry run to see if it goes bang or works! Plug in using a 3A fuse and an RCD device, install your starters and switch on...
DONT look directly at the tubes, UVA is very bad for your eyes! Both tubes should light and within 10 minutes be at full brightness. The workshop I tested mine in is fairly cold but the tubes were very bright in a short time.
If all is well, switch off and on to the next stage...
Step 11: Sealing the Whole Lot In!
Take your black card and your perspex sheet which should be the exact size of the inner lip of your box. The lid should close with the sheet in place.
Lay your perspex over the card and with a sharp scalpel cut around it. You should now have a piece of black card the same size as your perspex!
Taking a smaller rectangular shape (in my case a cutting mat) and have a look at where your tubes are in the box. Cut a smaller rectangle out of the card, this is where you will expose your PCB so it is best that the cut out is central to both tubes.
Tape the card down around your cut out edges so the card doesnt sag in the box.
Step 12: Nearly Done!
Next, we need to mount the perspex mounting blocks into the box.
In each corner of the box, in line with the top of the sponge lining, screw your wooden blocks in as low down on the block as you can without splitting it (use a small pilot drill at low speed).
Your perspex should sit flush onto the blocks and not bend or warp.
Place your perspex on and slowly drill a pilot hole down through into the blocks. Use a short, pan head screw to fix your perspex down to the blocks, dont go too tight or it may crack!
Step 13: Final Testing...
Make sure the box lid closes, everything still works and there is nothing rattling around inside...
I suggest leaving it on for an hour or so to make sure that nothing is going to fail or melt!
I made a sticker to place on top to remind me to switch off when opening the lid. UVa isnt very eye friendly.
Step 14: Thats It!
Well, thats it!
***UPDATE!***
You may need to diffuse the light using some milky acetate or white transparent plastic as sometimes it gives over/under exposure on the board edges but not too bad. Exposure time has a sweet spot of around 4 mins using standard board.
You should have a nice neat and portable exposure unit. There are several improvements you could make to your unit such as:
Interlock switch so the lamps come on after the lid is closed.
Electronic timer?
An IEC mains inlet so you can disconnect the mains lead.
More tubes!
Maybe white tubes on another switch to help with alignment?
You could also make this a double sided exposure unit with another box.
This box literally cost me no more than £30 to make. The nearest commercial equivalent is £150 so quite a saving!
I hope you have success with this box if you use it, you can make really good PCBs with the correct equipment and good quality fibreboard.
Enjoy!
- Sam.
***UPDATE!***
Electronic timer?
More tubes!
Enjoy!
- Sam.
