Introduction: Simple Up-Cycled Knife Sharpener
Using basic household materials and equipment, make your own knife sharpener!
Drill, Hammer, Chisel, Saw, Sandpaper, Cloth, Ruler
Flat stone, smaller stone, Water, Wood plank (roughly 400mm x 300mm), Pencil, Polish.
Step 1: Find a Stone
Step 2: Check for Abrasion!
Rub with sandpaper and water, if a paste is formed, it is suitable.
Step 3: Grind With Smaller Stone
Grind down rough areas until flat.
Step 4: Sandpaper Until Smooth
Use increasing grits of sandpaper to achieve a smooth finish.
Step 5: [OPTIONAL] Polish the Stone
Step 6: Plan Cuts on Wood
Measure thickness of wood and plan accordingly.
Step 7: Cut Wood
Step 8: Chisel Half Lap Joints
Ensure the joints are perpendicular to the board.
Step 9: Cut Pencil
Step 10: Sand the Pencil
Step 11: Drill Peg Holes
Step 12: Hammer Pegs
Step 13: Sharpening Your Object...
BE CAREFUL!
Push away from you and ensure the blade is straight. Make sure to use sharpen the whole of the blade otherwise the blade will become uneven.
